Item:HKS 2530 X2 TURBO FOR GTR WITH STAINLESS MANFOLD
Item Condition:USED IN GOOD CONDITION
Reason for Selling:PUTTING CAR BACK TO STANDARD
Price and Payment Conditions:COD,PICK UP OR DIRECT DEPOSIT, ASKING $3200
Extra Info:
Contact Details:
Edited by dinzlr
  • Replies 41
Posted Images
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
