yup, i bought a bosch as well and mercury in brisbane told me to get rid of it so got a walbro
no dramas with 200 (just a bit less ) rwkw
the 040s dont like to lie down in the tank apparently where as the walbro will fit like the original fuel pump
Yeah, ive had problems with walbro's aswell, 270rwkw we changed to a Bosch external... AFR's went straight into the 10's.
So the walbro was on edge @ 270rwkw
270KW...That's still pretty good!!!
I think I'd be scared at 250rwkw!!!
Impressive about the bosch though.
What do you think the bosch internal 040 could handle?
No it isnt :P Its nothing to do with the power.
Its not when its not performing like it should.
waste of $$, stick with walbro and you'll cry forever :(
quick question fellas,
I have a 33 with new motor havnt driven it yet. Turbo back exhaust, front mount. hi flow cat. 10-12psi on digital boost controller. airflow meter. avo blow off valve off a sti imprezza.
As i said i havnt driven it yet, will i need bigger fuel pump or reg?
sorry to hijack thread. I am a new member and i am having trouble figuring out how to start my own
Stock turbo I'm assuming? Stock pump will be fine.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
