  • Replies 147
OK, this is what we now need to do, organise EXACTLY who is coming and who isn't then once that is confirmed we can arrange who is bringing what, so if the thread starter could EDIT his original post so that like we can get a list of who's definitely coming that would rock as it would keep a nice point for us to refer to to know who is going so then we can arrange food etc, and for the rest of us, raise our hands to CONFIRM we're coming
ill be the first :D ME ME!!! IM COMING!!!
R31Nismoid you'll have a few weeks no matter what happens. It could be your last harah for a while though!
I gotta check what my mates are doing, but I don't think there is any reason why i can't come. I'll post a definite next week or so, it's still a couple of weeks off.
I need to get my tuned so i can hit the 200's round those bends :D (joking). Where's a good dyno-tune place east that knows their skylines? Might just go back to Ice unless there is somewhere closer to me (its a bitch getting to on the train to pick up/drop off!). Somebody mentioned a place in Mitcham?
If anybody wants a lift coming from inner east (glen iris) i can provide. I might bring a mate or two.
I really want to be there. Hopefully my Line is ready.
If not i will try to twist my mates arm to take his Line or another mate to come with his Cappacinoe. If the weather is nice we might take the roof off :D . Unfortunately no room for anything in the boot when the roof is in there ;) .
Originally posted by JET-33
apollo bay..dmn
thats a tank of fuel just gettin there :P
Yeah i know..
but the thing is.
There will be a lot of car clubs doing cruises from what i've heard around the traps...
And most will probably only go a far as lorne i'm guessing (usually works that way)
So if we go as far as apollo bay we should have less hassles getting parking/bbq's etc... etc...
we can stop at lorne is no-body is there?
but apollo bay is only an extra 30-40 mins... and some good twsits/straight in that section... coppers to though.
And Apollo bay only had Mobil 8000 last time i was there (for those religious to Optimax might have to do a lorne stop ?)
But stuff the cops. I'm coming REGARDLESS
:burnout:
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
