  • Replies 61
Yeah this kit is for GTS-T not GTR ( From Works )
I went into Works on Saturday arvo and they are out of stock but can order more in ( From what he was saying it sounds like they have some comming in anyway )
i am not sure what he meant. what is the difference with BNR and HCR. is that like 2 door and 4 door??
BNR is the GTR kit and HCR is the GTSt kit....theres a slight difference between the 2 and the fact that noone can find a BNR kit in AUS :D
Sent Worksauto an email about a group buy. Just a general one. Will let you know what they say. Ive got a few soarer mates wanting kits and few other mates with commodores.
Got a painter too, but ill have to ask him if he wants extra work :P
Group buy... i may be keen depending on price. Looking for a kit for a 34 - either a Bomex Type 2 or C-West at this stage. If anyones got photos of C-West or other nice kit on a R34, please post em of pm me.
Cheers!!
I am seriously thinking about making that BNR kit my next mod :D, not for a good few months/years and thats if I can find one as well. I just ordered my PFC so I'll have a decent 350-360hp at the rw's so you can't all say "its all show and no go". :)
Topaz: Sounding like a mean ride! :angry:
Yep, Works in Bently off Albany HWY near Chicken Treat etc..
If I find a good enough R32 GTST over the next month ( been looking for way to long.. I must be fussy ) Then I would be interested in a group buy if I can get the Do-luck kit cheaper.
Drift kits makes your car very low and that is a bit of a problem with the speed humps these days. it just looks funny when the height of your ride is a lil high too.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
