Item:
1 x R34 RB25DET NEO Turbo
Sydney Northern Beaches
Prefer Local Pickup to save Delivery hassles; but can organize at buyer's added expense.
Item Condition:
* Excellent Condition
* Less than 1mm Shaft Play (in all directions)
* Seals in perfect condition
* Absolutely no oil found in the intake
* Checked by 2 mechanics for above condition report
Reason for Selling:
Upgraded to a bigger turbo... seeking more boost :)
Price and Payment Conditions:
Chasing $600.00AUD excluding delivery charges.
Payment through Direct Deposit or Cash upon Pickup
Extra Info:
* Standard wastegate is not included as it has been re-used for the time being until aftermarket wastegate is purchased.
* Turbo has been cleaned and conditioned after removal.
* No mounting hardware is included as this has been re-used as well.
* Turbo is ready to go right now.
Contact Details:
Please send any queries or offers to me through PM or SMS - 0415 263 309.
Edited by satanic
https://www.sau.com.au/forums/topic/105090-fs-r34-rb25det-turbo-standard/
I don't know a lot about the turbos, but I havre read that the 34 turbos are larger (housings) which make them the ideal turbos to hi-flow.
Had a few offers, only one or two who are actually genuine... please do not send me PMs with stupid offers.
Thanks
Stan
the series II r33 is the same turbo as a r34 gtt
it is a little larger that the first series and has a ball bearing core.
the compressor wheel is nylon which is lighter making it spool quicker. most people are scared off by the thought of a 'plastic' wheel in their turbo but it is the exhaust wheel that will spit as a result of running too much boost for a period of time.
both series turbos have ceramic exhaust wheels also to aid in reduced spool up time.
great turbo. i have one on my rb20. very fairly priced at $600.
You can't see it in the photos because it doesn't come with it... this was clearly stated in the first post; sorry about any confusion caused.
Turbo is still up for sale...
This is a great price..
Take this turbo to ATP(Melb) or GCG(Syd) and get a "sierra/sierra" hi-flow. Whack it on you car, install Tomei Poncams and you should see at least 250rwkw.
I have a 33s1, with Tomei Poncams and Head porting, and am making 274rwkw@16psi. Due to std bottom end, i decided not to push the combo any further, till the forgies are installed. Can't wait till i have 20psi, and start to experiment with the adjustable EX and IN cam gears :(. (PM Bassjunky for details on IN cam gear adjustment :), it can be done while still retaining the VCT )
Even in stock form this turbo should make more power on a 33, till you are ready to hi-flow it :)
Good Luck with the sale
Thanks Al
Even though I had very limited understanding of what the above actually meant technically, yeah, what he said :(
All those guys who PMed, I have replied...
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
