ok, my car has been doing this for a while and its pushing me to breaking point
basically, the indicator noise comes on randomly (the actual indicators arent on, ive checked)
so just driving along, you get click click click ....... (nothing for a few minutes then) click click click
occaisionly i am seeing whisps of smoke out of the steering column
the indicators all still work fine, everything on the column does
I JUST CANT STAND THE NOISE ANYMORE
anyone know someone good with skyline auto electrics?
https://www.sau.com.au/forums/topic/105108-indicator-clicker/
Wouldn't the puff of smoke tend to indicate the indicator switch is stuffed or shorted???.. its in your steering column...
Pull it out (it pulls out), and buy another one. If it is stuffed the indicators wouldn't work.. From what I remember you'll have to take off the whole steering wheel to get in there.
Actually.. its probably just a short.. Only one way to fix that one.
You been playing with a boss kit lately?
Edited by predator
not lately, but i do have a nardi wheel
its weird, coz the indicators have always worked fine, even when the steering column is smoking;
its just the incessant clicking, always clicking, click click CLICK EVEN WHEN IM NOT IN THE CAR I HEAR THE CLICKING, I CAN HEAR IT NOW
ok, maybe its not that bad, but its getting there :cheers:
Its probably not your indicators if they are working OK.
Probably a relay of some sort in there for something else.
Clicking is the relay switching on and off and smoke is not good.
Has anything else stopped working, wipers rear wipers, hazard lights, alarm, high beam, check everything
I would be doing as mud has said, pull the covers off & go for a drive, oh & make sure u have a fire extinguisher in the car, if that relay sticks shut due to the short (melt the contacts together) you will have a fire...
Another way to do it is to pull the fuze for the wipers & go for a drive then do the same again with the horn fuze. I would not do the same for the indicators though. Process of Elimination...
oh & another thing becareful if the cars got a air bag if its some thing to do with the slip ring it can go off in your face all the bags need to be set off is a spark...
I know some people will say u can not set a air bag off with out being in a smash, wrong if u get a power supply to the detonator, bang bag deployed...
he said he has a nardi wheel, doubt it would have an airbag. anyway... soldier on.
yer, no airbag
its a hard one to diagnose, as on any given day, it will be fine
then the next not
as for the smoke, its even rarer, only happens everynow and then (last time was driving down the coast to the bdo, and there was a fair bit of smoke)
ill test everything tonite to make sure everything is working, but it was all working last time i checked
I have had this about a year ago and fixed it by replacing the indicator stalk. (I know what you mean about it driving you craaazzzzy)
When I inspected the old one it had blackened areas where you could see tracking and arcing (it looks like a pretty complex switching arrangement).
El Bee
My indicators have also recently just started to click sometimes randomly but mostly only when i indicate right and the indicator is then turned off, it keeps clicking alot faster.
I've got a mate who's a auto electrican thats fixing mine.
Anyone interested in getting theirs fixed, let me know and he might do yours for you's as well.
mate, ive just sent you a pm;
lunchtime today there was a lot of smoke and a bad smell (as well as the clICK CLICK CLIKC CLICK CLICKC LICKC LCIK)
im gonna go get some quotes saturday morning from local auto electric places also;
bloody money pits!
i had this problem, fixed it by changing whole indicator and light switchs. Got the part from a wrecker for arounf $100, easy to do, take off steering wheel, few screws, unhook some wires, change over then put it all back together and your done. I looked fixing mine to sell but its just all metal slides etc, wouldnt know where to start!
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
