to the 1% of guys with an auto box, do you guys know where to fill up an r32 auto box with transmission flluid?? my friend thinks the power steering tank is the same as the auto one, is this true??
Nissan normally spec Dexron III ATF, choose a good quality synthetic ATF like RP max-atf or Redline high temp atf will do you good in the long run.
r u talking about an r33? cause the only thing on the left closest to the firewall behind the strut tower is the brake fluid bottle, and i cant find any yellow dipstick besides the oil one in the engine bay, does anyone know where i can fill atf on an auto r32 rb20det?? trex101??
Nope, got no idea.
thanks guys for all the help, since were all on the money i got another issue, mines full now but still doesnt change gears occasionally leaving the lights, i need to switch the car off and turn it on again for the gears to work, auto specialist reckons i need a full service for about $200 he vacums out the inside, could it be an electrical fault however??
...my fluid is very clear
Thats normal.
and very low
To get the correct level reading the trans should be at normal operating temp, so go for a drive around the block couple times & during which you should manual shift through the gears. Then with the engine still idling check the fluid level as you would with the engine oil. So if u checked the level while its still cold it prob showed it was low, so lets hope u didnt overfill to much.
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
