NOW DEFINATELY FOR SALE...
Just wondering if anyone was looking for a project car. I have blown the number 5 cylinder and looking at getting rid of her. has brand new garrett 2530 turboes, hks intercooler, hks turbo back exhaust, hi flow cat. tien suspension... and plenty of extras.
let me know by pm. or 0421544598 if any one has interest in this car. POA
Looking for offers around 12.5k...
Located in perth. has 3 months rego remaining.
https://www.sau.com.au/forums/topic/105633-blown-gtr/
let me know if you want to sell the turbo setup and fuel system.
https://www.sau.com.au/forums/topic/105633-blown-gtr/#findComment-1944840
wow...
rb30 bottom end = $100
sump adapter = $500
say $2K for fitting it all together with required belts and hoses.
you'd have a newly built 3L gtr for about $15K
oh how I wish this was in a different time in my life..
*SIGH*
If only it were that simple
Flyying
PM'd you yesterday
https://www.sau.com.au/forums/topic/105633-blown-gtr/#findComment-1947938
Lol, i can field these for him and it's not even my car.
It's an R32 (look under his avatar)
And it will cost around $500 to ship it, although thats a question the buyer should be finding out themselves.
and it's certianly not as simple as an RB30 bottom end, R34 is right..."it never is"
https://www.sau.com.au/forums/topic/105633-blown-gtr/#findComment-1948124
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
