im lookin at gettin my car down into the 11s, and maybe 10s (in-time)
besides all the other stuff that obviously needs to be done, what do u guys think is the best size cooler and turbo to get?
at the moment im leaning towards a t4 cos i want to run mega boost in my car..over 20/25 psi, but i want it to kick in early, like still at 3k rpm, not 6k
any ideas?
https://www.sau.com.au/forums/topic/10570-fmicturbo/
What sort of hp figure are you chasing?
IMHO, you are better off running the lowest boost that you can. Dont confuse boost pressure with air flow. It is possible to get a turbo to pump more air at 1bar than another turbo pushing 2 bar, the lower the boost the less likely you will experience detonation. Also with higher boost pressure, you may have to decompress the engine = worse off boost response and less torque at lower revs, something I would like to avoid.
It appears to me that sometimes people use boost pressure to overcome a poorly flowing engine. If you get your head ported, manifold and plenum match ported (with a decent plenum), and a decent set of cams and cam gears, you will be able to get alot better power at lower boost - with the right turbo.
As an example, AED can flow an RB25 head to 403hp at atmo, and Darren is quite confident that 600hp would be easily achievable at 1 bar.
Just some food for thought, decide what your hp goals are, and see what the best setup would be to achieve this with lowest possible boost - within of course, your other requirements of where you would like boost to come on.
Remember aslo, that in an ideal world, we would be able to make 600bhp with boost hitting hard at 1500rpm, but this just will not happen - the bigger the hp you want, the more lag to expect within reason.
Just my 0.02
Steve
https://www.sau.com.au/forums/topic/10570-fmicturbo/#findComment-169871
Yup as Steve said, choose a HP figure and build around that.
I see way too many people buying the biggest turbo and biggest fmic they can find and it just doesn't work together and they either end up with serious lag or way under the power figures they were expecting.
https://www.sau.com.au/forums/topic/10570-fmicturbo/#findComment-169981
You need between 350 and 400HP at the flywheel to get the 11's all things being equal. More horsepower makes that task easier all the same, so why not 800HP?
Readings at the tyres are not what you ought to interest yourself in. Get components together for an engine power rating.
A good ballbearing turbo, airflow rated at 420-450HP should do the trick, then a intercooler of the same rating. Then do everything else that needs doing for that power, to make the motor last.
https://www.sau.com.au/forums/topic/10570-fmicturbo/#findComment-170314
hmmm..start saving!! to get you up to that is probably going to cost you the best part of $10k (depending on how you source your parts). Every second off is $$$ and it goes up and up.
Do you want to get those times for coolness factor or to actually use on a track in drag or racing??
You might actually find that as you go up you might have second thoughts about having something that quick (try that in the wet :D). Seems like you are chasing something truly quick but as you get into it more, because of reliability, safety and above all cost (petrol costs, rebuilding engines, running back and foward, etc, etc) you might have second thoughts.
https://www.sau.com.au/forums/topic/10570-fmicturbo/#findComment-172140
Here is an example : 400Hp or just a snick under in a car that weighs the same as an R33 line (VH commodore) low 11's all day on street rubber, 10's with slicks.
Skylines are not a special case. Apply the basics with that much power and you will get the times.
https://www.sau.com.au/forums/topic/10570-fmicturbo/#findComment-172674
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
