I’m surprised no one has brought up the mass the fan adds to the rotational mass of the engine!
From this thread and a few freinds lecky fan attempts I’m understanding that a shrouded, setup, either moded stock one, or custom, f.glass, sheet alloy'd 16" thermo would do.... but i cant STAND that weighted free revving feeling and EH Falcon engine fan noise of a skyline! Lighter flywheel would fix some of it I guess.
Be interesting to check the physical tourqe loadings that a alternator puts on the engine from normal electronics + 10AMP thermo.. and how that compares to the stock locked up engine clutch fan; truley see witch one costs more power, over the cruising, WOT etc that makes up fast street / track running.
In all honesty I would try v.hard to make a thermo work properly due to engine response and noise soley, flame away !!
I believe there’s a array of simple jaycar kits, mechanically switched, or electronic that you could use. Could get fancy and use a PICAXE to control both thermo and electronic water pump, tricky closed loop, solenoid on the thermostat to run a cooler water temp, read: head temp when in high boost mode, and then a higher more emission friendly temp when cruising. Just my way of adding complexity & possibility to a simple thread - sorry :O
- M
  • Replies 65
Posted Images
GeeTR,
When I had the thermo's on it was wonderfully quiet. You don't realise how much noise the std fan makes until its gone. :O
I swear the car did feel a little more responsive ESPECIALLY in hot weather.
I have plans to throw thermo's back on but it will be some form of el factory thermo's.
Yay, acceptance! Amen cubes
Dammit, have 6:30am start, but I have this notion of controlling water temp accurately and quickly to use as another factor you could control, stuck in my head- argh.
I know Bemma and others have been doing it for a while on the specy'r models. Surely just a stepper motor on the stock thermostate or a custom stepper’d valve wouldn’t be hard. Do that multi head coolant bleed setup thingo which is popular of late... you could spend many a weekend tweaking.. if only the time and money *sigh*
- M
I have to admit I reckon thermos are the shiznet even though everyone says that they aren't worth it.
I hate the blowing noise the stocker makers, especially in the morning!
I haven't had a fan shroud for 3 months now and with the new radiator I've never seen it go above 82 degrees (still with fan though) even when driving for an hour with the Air con on. I also used to see the oil temp go up a little with the Air con on, but not now. Yay for biggins radiators.
So, I reckon it's only a matter of time before my stock fan totally accidentally and mysteriously breaks and I have to put a big thermo on.
REV210
As you are MR "Lower your rotational mass" on SAU, have you done this mod?
How did you go with engine cooling?
Did the fan come on and off and sap engine power at all?
Tell me your results!
BASS OUT
I cant believe you think your going to get an increase in power from the lower rotational inertia just by removing the mechanical fan.
The rotational inertia would equate to maybe a couple hundred Watts, not kW.
electric fans are better than mechanical purely from a control perspective. They flow less, but transfer the energy required from the crank to the alternator.
Its not a power gaining mod. More an engine saving one!
Think of it this way, at start stop traffic engine speed is slow. Fan speed is proportional to engine speed (hence so is flow, so long as cavitation isnt present). Electric fans arent related to engine speed, rather engine temp.
Edited by AndrewD
Well I still reckon some bored young aspiring mech / elec uni eng, needs to rig an electrical water pump, thermo and some form of PIC. Have some fun playing around with cooling, assuming both units down mind less the 12v
Davies Craig have just released a variable speed controller which allows the operator to select the heat that he wants to water to be at. From 75 degrees up to 105 degrees.
REV210
BASS OUT
No actually I am MADAM " Lower your rotational mass" as I am into drag. :(
Yep did the mod a few times to different cars.
The engine goes well with cooling as I retain the fan shroud and use an appropriate size/ cfm fan.
The fan is normally 'on' in the low speed and stand still situations and off as the car is moving at speed.
The 'at speed' part is what the performance angle is aimed at, particularly as the belt pulley drive horsepower losses grow as engine speed and load does. It's when the hammer is down that you like to have the benifit of a redundant fan being driven.
Never really 'measured' the results as I thought them obvious but, I'm sure the might be a test somewhere if googled for.
Most factory skylines fan shrouds will accept the very large 16 inch davies craig fan with a little cutting to size.
Air guides for both the intercooler and radiator are worth chucking in too if you have the inclination for extra efficiency. Some foam can be used if your not a welding type.
AndrewD,
Rotational intertia doesn't equal horsepower to clear that up.
The weight of the factory fan gone helps improve the engine accelleration a small amount, combined with other pulleys made of lighter material it all adds up to help more.
The weight of the fan on the end of the water pump pulley increases the load on the belt, which increases the fictional power losses.
The benifits you mention seem quite valid by the way.
The reliable nature of the pulley fan has it over the electric fans however. If any part of the electric circuit goes down you have no fan, for the pulley fan to fail the water pump pulley has to fall off. For this reason an electric fan has to be done right with the fail safe fuses and relays and spares of these in the car at all times perhaps with a warning light for good measure.
The altenator doesn't kick in tho to keep up with the current draw tho does it? I though that it just span at the same speed always spitting out the same power...
But what is an extra $90 for a ground stabalizer to help the electic system keep up...
no it doesn't but when you load up the alternator, the engine comp often loads up the engine a bit as the alternator needs to spin a little faster to compensate.
You can feel it sometimes and if you turn on the high beams you can often watch the revs rise.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
