  • Replies 84
Weekdays are great for L2S practice days at EC.
I've been to 2 or 3, and there have been around a dozen cars at most. And the guys who did it were reasonable drivers in reasonable cars (myself excepted).
But there were a lot more race cars out there, as well as bikes, so you didn't get as much track time.
I'll be out at EC this Saturday for L2S practice since I can't make Friday (and some friends are going). If I get there and there are too many fooli sik cars I'll just go home, but otherwise it'll be nice to get some driving happening.
hmmmm... be watching this space... been wanting to get my car on the track for a while now... is an oil cooler essential? i dont wanna cok my fresh engine
Not essential, but worth while. I have been getting around it for 2/3 years by taking it easy for a few laps after flogging it for a few.
Looks like there is definatly some interest, and we discussed some options at our Committee meeting last weekend, looks like something will go ahead soonish.
Watch this space!
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
