Hi all...im thinking of removing the rear spoiler off my r33 gtst s1....i want a different look, as there are too many gtsts going around with gtr or stealth wings...has anybody got any pictures of how its looks...my car is wine red so if anybody has any pics of a wine red r33 without a rear spoiler that would be great...and yes i would weld in the holes and do a respray...cheers
it will look shit, trust me !!!
if you want the no spoiler look, your going to have to buy a new boot, plastic moild that lifts the top of it up so it doesnt look too stupid, have a close look at your spoiler, ur boot sinks down, and the spoiler takes up the gap
"will look shit, trust me !!!"
Personal taste, lets not forget that HZ GTS's are not Monaros....
If you want to be different get a c/f or fibreglass rear boot which is moulded to be level with the 1/4 panels, they look good. If not then just weld the holes, fill the "slots" where the original wing went and have a smooth lid. Its all personal choice,
Twas pretty easy, just take out some screws and if you change your mind....put the screws back on.
I took the wing off atthe national museum while we were cruising, the cops that roled up couldn't figure out why i was fu**ing with my own car lol.
yeah i took mine off for a while too, maybe 2 days. but after looking at it for a while i came to the conclusion that it didnt really flow. but again its all to do with personal preference.
IMO, i reckon flush mounded lip spoilers look better.
if you run no wing the quarter panels will be exposed.
by memory you can see where the panel wraps up and over, and see the spot welds etc
ie. you won't see a neat flat painted edge...
guess you could bog and spray the bat wing bits but that's alot of effort IMHO
i had the holes welded when i had the paint job done.
also theres a bit that sticks out on the inside of the rear panel that i had flattened so it looks cleaner.
i like it better without the wing.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
