I don't think there is a GT-V
there is
25GT
25GT FOUR
25GT Turbo
25GT-X
25GT-X FOUR
25GT-X turbo
GT
So i'm guessing you mean GT-X. They are like the luxury spec but outside there is no difference at all. Just the rear spoiler is a bit lower if it has one and no intercooler intake in the front left of the frontbar.
https://www.sau.com.au/forums/topic/106166-r34-gt-v/#findComment-1956873
The R34 GT-V is basically the chassis, driveline and components (eg brakes, suspension, LSD) of a GT-T, but with the RB25DE.
http://www.nissan.co.jp/SKYLINE/0001GT_V/
http://www.nissanperformancemag.com/may03/skyline_gtv/
//edit: removed incorrect statement.
Edited by raz0r$harP
https://www.sau.com.au/forums/topic/106166-r34-gt-v/#findComment-1956903
If you're looking to import into Australia under SEVS, note that non-turbo R34s are ineligible.
Hrm.
Jspec have a few up, as do Prestige.
How come ineligibility?
Thank you for your help :P
https://www.sau.com.au/forums/topic/106166-r34-gt-v/#findComment-1956915
the only way you could tell is if you walked around the back and looked at the badge, if it is still in place.
25GT being the V and of course 25GT-T being the turb'd one.
because the GT-V has the GT-T alloy wheels there is no other external visual clue.
unless of course you looked in through the windscreen to look for the 3 gauge console on top of the middle of the dash which the turb's have and the V won't have.
i have a manual GT-V sedan arriving next month with any luck
https://www.sau.com.au/forums/topic/106166-r34-gt-v/#findComment-1958711
no
the 25GT's do lack the GT-T interior, alloys, brakes, suspension, front strut brace, HICAS and rear stabilizer.
from my print out the 25GT has no LSD
it also states an auto GT-T/GT-V has a 'rear screw refuse LSD' and the manuals have a 'rear helical LSD' but I'm sure most of you would know that.
https://www.sau.com.au/forums/topic/106166-r34-gt-v/#findComment-1961064
Nissan R34 GT
Sedan
5 speed manual
1998cc
GF-HR34 frame
RB20DE
Sedan
E-ATx 4 speed auto
1998cc
GF-HR34 frame
RB20DE
Coupe
5 speed manual
1998cc
GF-HR34 frame
RB20DE
Coupe
E-ATx 4 speed auto
1998cc
GF-HR34 frame
RB20DE
Nissan R34 25GGT
Sedan
dual matic M-ATx 4 speed auto
2498cc
GF-ER34 frame
RB25DE
Coupe
5 speed manual
2498cc
GF-ER34 frame
RB25DE
Nissan R34 25GGT-X
Sedan
2498cc
GF-ER34 frame
RB25DE
Nissan R34 25GGT
Coupe
2498cc
GF-ER34 frame
RB25DE
Nissan R34 25GGT FOUR
Sedan
4 wheel drive
5 speed manual
2498cc
GF-ENR34 frame
RB25DE
Sedan
4 wheel drive
E-ATx 4 speed auto
2498cc
GF-ENR34 frame
RB25DE
Coupe
4 wheel drive
5 speed manual
2498cc
GF-ENR34 frame
RB25DE
Nissan R34 25GGT TURBO
Sedan
5 speed manual
2498cc
GF-ER34 frame
RB25DET
Nissan R34 25GGT-X FOUR
Sedan
4 wheel drive
E-ATx 4 speed auto
2498cc
RB25DE
GF-ENR34 frame
Coupe
5 speed manual
2498cc
GF-ER34 frame
RB25DET
Coupe
4 wheel drive
E-ATx 4 speed auto
2498cc
GF-ENR34 frame
RB25DE
Sedan
2498cc
GF-ER34 frame
RB25DET
Coupe
2498cc
GF-ER34 frame
RB25DET
Nissan R34 25GGT-X TURBO
Sedan
5 speed manual
2498cc
GF-ER34 frame
RB25DET
Sedan
2498cc
GF-ER34 frame
RB25DET
BREAKDOWN
GT
sedan - manual
sedan - auto
coupe - manual
coupe - auto
25GT
sedan - dual matic auto
coupe - dual matic auto
coupe - manual
25GT-X
25GT 4
sedan - manual
sedan - auto
coupe - manual
coupe - auto
25GTT
sedan - manual
coupe - manual
25GT-X 4
sedan - auto
25GTT-X
sedan - manual
NOTES
They all have ABS
LSD diff is an option for the RB20DE and RB25DE, and standard on everything else
Satellite navigation is an option for all the cars
Side airbags are also an option for all cars
All the 4 wheel drive R34s come with 15" rims and they are all RB25DE
RB20DE R34s come with 15" rims
RB25DE R34s come with 16" rims
RB25DET R34s come with 17" rims
GT-X is only available in sedan
All RB25DET come with 225/17 tyres
HAVENT BEEN ABLE TO FIND ANY INFO ON THE R34 GT-V. ANYONE ACTUALLY OWN ONE?
https://www.sau.com.au/forums/topic/106166-r34-gt-v/#findComment-1991723
Actually... bayside blue was an option on models other than the GT-V a couple of months before the GT-V went into production.
Also if you didn't get the series 1 GT-V (jan-aug 2000) you got the hideous Series 2 R34 narrowbody bumper as standard. Interestingly the second series GT-V's also dropped a few nice colours like red and yellow... possibly due to lack of interest from new car buyers in japan.
https://www.sau.com.au/forums/topic/106166-r34-gt-v/#findComment-2025691
    • Get an inspection camera up there.
    • Yeah, but look at the margin in viscosity between the 40 and the 60 at 125°C. It is not very large. It is the difference between 7 and 11 cP. Compare that to the viscosity at only 90°C. The viscosity axis is logarithmic. The numbers at 90 are ~15 and ~35. That is about half for the 40 wt oil and <half for the 60. You give up viscosity EXPONENTIALLY as temperature rises. Literally. That is why I declare thicker oil to be a bandaid, and a brittle one at that. Keep the oil temperature under about 110°C and you should be better off.   Having said all of that, which remains true as a general principle, if you have indeed lost enough oil from the sump that the pump was seeing slightly aerated oil, then all bets are off. That would of course cause oil pressure to collapse. And 35 psi is a collapse given what you were doing to the engine. Especially if the oil was that hot and viscosity had also collapsed. And I would put money on rod or main bearings being the source of the any noise that registered as knock. Hydraulic lifters should be able to cope with the hotter oil and lower pressure enough to prvent too much high frequency noise, although I am willing to admit it could be the source.
    • Thanks for the reply mate. Well I really hope its a hose then not engine out job
    • But.... the reason I want to run a 60 weight is so at 125C it has the same viscosity as a 40 weight at 100C. That's the whole reason. If the viscosity changes that much to drop oil pressure from 73psi to 36psi then that's another reason I should be running an oil that mimics the 40 weight at 100C. I have datalogs from the dyno with the oil pressure hitting 73psi at full throttle/high RPM. At the dyno the oil temp was around 100-105C. The pump has a 70psi internal relief spring. It will never go/can't go above 70psi. The GM recommendation of 6psi per 1000rpm is well under that... The oil sensor for logging in LS's is at the valley plate at the back of  the block/rear of where the heads are near the firewall. It's also where the knock sensors are which are notable for 'false knock'. I'm hoping I just didn't have enough oil up top causing some chatter instead of rods being sad (big hopium/copium I know) LS's definitely heat up the oil more than RB's do, the stock vettes for example will hit 300F(150C) in a lap or two and happily track for years and years. This is the same oil cooler that I had when I was in RB land, being the Setrab 25 row oil cooler HEL thing. I did think about putting a fan in there to pull air out more, though I don't know if that will actually help in huge load situations with lots of speed. I think when I had the auto cooler. The leak is where the block runs to the oil cooler lines, the OEM/Dash oil pressure sender is connected at that junction and is what broke. I'm actually quite curious to see how much oil in total capacity is actually left in the engine. As it currently stands I'm waiting on that bush to adapt the sender to it. The sump is still full (?) of oil and the lines and accusump have been drained, but the filter and block are off. I suspect there's maybe less than 1/2 the total capacity there should be in there. I have noticed in the past that topping up oil has improved oil pressure, as reported by the dash sensor. This is all extremely sketchy hence wanting to get it sorted out lol.
