Hi i recently got my Ps and started driving my 92 R32 GTS25 by myself and i have filled up twice now and i think im getting really bad fuel economy. Im a pertty big noob when it comes to cars so i couldnt really tell u wat mods i got. Both times i did around 320 km per full 60L tank and i asked a few ppl and their gtrs do better then that so im just wondering if there is anything wrong and if your guys got any suggestions thx
https://www.sau.com.au/forums/topic/106384-r32-fuel-economy/
Such a large factor with fuel ecconomy is dependant on how the individual drives the vehicle...
e.g. Car: R32 GTS-t
Mods: Lots...
Good week at work, 400kms easily...
Sh*t week at work - girlfriend - momentary fits of rage, 253kms (and own PB)
It really does depend mate... also, mods? Any? It's an RB25, and you might have your lead shoes on...
But around the 330 - 400 mark I think you'll find is pretty stock standard.
Cheers. :unsure:
Do a major service on your car, something sounds wrong on yoursl ...my r32 na does way better than that on a full tank like 400-500+kms., with the occasional flooring it lol.....
some advise, watch your fuel guage when driving normaly, then watch it when you floor it a few times the fuel guage shows how much you really use when doing that.
Edited by NeesaanGTS
auto rb25t with 190rwkws and i get 370 to 450 from 60l champ
thats 15L/100km ! thats hardly good either..
acidkid: if yours is auto that could explain a lot.. seems like economy on the autos is quite a bit worse than the manual.
I get something like 130 - 140 klms per 15 litres for my manual r33 - Though just today i got 120 in about 20 ltrs ( but thats cos I had a full tank, and i was demonstrating the turbo for a couple of my friends).
who cares about fuel economy, you drive a skyline not a toyota echo,
if i want fuel economy i wouldnt be driving a skyline,
enjoy it while petrol is still affordable, theres less and less oil in the world, in 10 years time we'll prob be paying $2- $3 a litre
yeah. at the start of each tank i've been known to say many a time "okay, no hooning it for the whole tank to see how many Ks you can get" ... well, that plan always goes out the window.
i get a bit over 300km to the tank most of the time. i should change these o2 sensors like everyone says! i have trained myself to always just put it in neutral down hills and rolling toward the lights though.
my car is r34 gt4
i got 21 litre per 100 km
i think it's very bad
i already check once by maintenance man. they check exhaust emission. and said no any problem...
i want to know: how to check o2 sensor? and can inject oil to tank fix problem?
i bought this car form japan, nobody driver it in nearly half year, is this reason for fuel problem?
if your car was turbo i would say that u should be able to get more but NA you should definately be getting more, probably should be closer to 450. Definately get it checked out by an EFI diagnostic center.
Edited by RRR32_GoDzIlLa
If you put it in neutral that would use more fuel according to my understanding.
When you put it in neutral the motor has to dump fuel in to stop the car from stalling. If you are rolling down a hill or rolling towards the lights in gear you are using less fuel because your motor is turning itself from the momentum of your wheels. I think most ECUs cut fuel on deacceleration.
Someone correct me if I'm wrong.
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
