Noltec Rear subframe mounts
I will be commencing a group buy as of now for the following items :
N92447 - R32 & R34 rear subframe mounts
N92446 - R33, S13-S15 Sylivia, 300zx Z32 rear subframe mounts.
These are replacing the rubber / silicon filled rear mounts that wear over time and cause movement in the rear subframe.
My r32 is a street driven car and under load (on boost) you can feel the rear end sort of squirm around.
People normally fit the alloy type rear subframe bush, which just crushes down the factory worn item, resulting in increased vibration, and noise through the car as the cradle is now metal on metal.
You can fit these noltec items, and still fit the typical "pinapple" urethane type bushes to angle the cradle for drift or traction.
below is attached an expalnation of what i mean.
Fitting of these can be done in two ways :
1. workshop can fit for you
2. remove rear cradle yourself, use a holesaw to cut out old bushes, then whack these in.
Or do a search :D
Noraml RRP on these is $266 from Noltec.
If we can secure 5 buyers for each, i can do 1 set (4 bushes) for $155
Im in Adelaide, so pickup is available or postage will be +$6 around Australia.
If more than 5 order i will place the first 5 order in straight away, and start a new list then the next list will wait till i have 5 on that one and so on.
End date : 2 months from now = 21-4-06
thanks ;)
https://www.sau.com.au/forums/topic/106735-noltec-rear-subframe-mounts/
  • Replies 181
Posted Images
hmm i kind of get the picture of how these are fitted do you know of any links to show how to fit them>? i was going to get some pine apples (otomoto BEE R ones) as well might as well put me down aswell for r32.
cheers simon
Edited by gt-t_r34
none for R31 GTS-X?
Noltec dont list them in their parts list i have. sorry :P I can get other stuff for the r31 though.
Im in Adelaide I will take a set for the S13 what do I need to do, any deposits needed and when will I be able to get them?
Ill add your name to the list, and when i have 5 orders i will ask for payment, then i can place the order. Once i have them, i will let you know, and you can pickup or i can post.
So if you know anyone else with a s13-s15 or r33 tell em to buy a set, and i can send the order off when i have 5 orders
dunno what the deal is, the r32 and r34 use the same replacement, but r33 uses the same as s13- s15 and z32.
I could email the supplier and find out if your really keen :P
Yeah that would be cool - if it's not too much hassle.
I've purchased these mounts (pictured below), and have been told they fiy S13/S14/Z32, I assumed they would fit my R32 as well. If it looks like they wont, I may have to jump onto your group buy.
Ryno
Those black ones, look like a solid metal replacement for the std rubber bushes.
If they are, it will be a noisy ride :D
Dont know if they are the same as the ones Noltec sell. What are they made of?
The advertising for them states: "They are machined from virtually unbreakable Duravar® UHMW Polyethylene. These mounts are much harder than polyurethane or rubber and will never wear out."
If they fit my car, they should work well... They have no metal parts to them, so they should have minimal road noise.
B1- i can get any parts that Noltec offer for around 20% off their retail.
If i can secure 5 orders of the same item i can get a total of 40% off.
For the rear they make upper control arm bushes (camber kit).
Fronts they do control arm bushes, radius (caster) bushes/rods, engine mounts etc.
Let me know what your interested in :)
edit/ i'll look into doing another group buy this week containing control arm bushes and camber kits etc.
Edited by Bl4cK32
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
