cant believe ir just read 13 pages of all this
1.4 sixty foot and 129 mph and only a 10.8
you need to changes gears faster that thing will go 10.1 with ease.
or get an auto.
good work i like it.
our cars would be a good match up.
Yeah love to champ
Reason why i didnt flat change is the scared to blow the box and thats useless money
I have just finished putting the auto in and have driven the car but have noticed i have only got around 4-5 psi of boost
I am going to check this problem out and Do a comparence dyno printout from Manual To auto.
The box i am running is a 2 speed powerglide with transbrake.TCT Converter With a mech Diode
I have also got a Chrome moly 1 piece tailshaft made to help with the transfer
I will post tomorrow the difference and will be back at the track in 2 weeks
My next aim is to run in the 9 second area.If it cannot be done with the standard head which i think is possible with some Nitrous but if not i will use the Solid lifter head which i have got with a steel head gasket.And that also goes if the head gasket goes i will also change heads.
Edited by MR331307
I cant believe that rb25 is still going. I hope my rb30det can make 400rwhp in stock form and be reliable!!! if that rb25 can do then mine can get close to it im sure :cheers:
Hey Guilt-Toy, I have an internally stock (apart from poncams) rb25 making 410.7rwhp and it is running fine. It is on a conservative tune with timing advance and a/f ratios to keep it running as long as possible. But then again others running less have had the motor pop. I guess a lot has to do with the tuning and the condition of the internals to begin with.
Cheers,
JB
Ok have run the box in a bit on the dyno and have done 4 power runs
Without modifying the tune i have made 477 WRHP with the auto on just 18 psi Boost
Before the auto i was making on average 500 RWHP on 18 psi of boost on pump fuel
I will post the nitrous compared sheet next week when im back from Newcastle as well as this sheet
But as far as what i can see i only lost 23 RWHP
I also tried to spool it on the brake and found it couldnt get more then 3 psi
I tried with the nitrous and it flared straight away
This is due to the converter being a Transbrake Nos setup converter
The converter Was built by John @ TCT in melbourne which i think did a unreal job and the box was built by Joe @ Wollongong Automatics.
I should be back at the track in 2 weeks now
Waiting on the car to be teched.
My aim is to run in the 9 second area and further till something gives way.If something does i will change motors and try eventually to run into the lower 9 area.
Any questions just ask
Edited by MR331307
1200hp would be good for 8's or 7's wouldn't it? whens the beast arrive?
Im using this engine in my Full chassis car that my father and i am building
Im using the other engine i have in this one
the one with the solid head ETC
i do
but i am not allowed to Show the Setup
(FAMILLLLYYYY MATTERS)
when its closer to being @ the Track ill post some photos of it and the car
This is what is in the Motor im putting in this Car
-RB26 Crank
-N1 oil Pump
-EAGLE H beam Rods
-ACL forged Pistons
-ARP main & head Stud kits
-Cometic Head Gasket
-RB25 Head with TOMMIE Valve Springs,Solid Lifters,Tommie 272 @ 11.5 lift Cams
Aiming For 600 RWHP+++ and a low 9
Edited by MR331307
hey bro, look ive just spent the good part of 2 1/2 hours reading this thread and its my bloody birthday, ive even held of on the cake till i read this, lol. What a thread, one of the best of read on this site. To the doubters out there, well you said he was dreaming and the dream came alive. The power you got out of the engine was pheonaminal, it makes ya think what a 13 odd year old engine can actually achieve. To the believers, aim high and you can go far. I know that the availability of a dyno and the mind of someone like your self (mechanicaly) not everyone has, but you took advantage of it and done well. That engine had a lot of balls. Anyway good luck with the new one and who knows what power you'll hit with this one.
Damo
Damo
LOL HAPPY BIRTHDAY BRO
Anyways ill post some picts of the Internals
If i wasnt Selfish and didnt try to get more power out of it i would say it would of Lasted alot longer but i was always Trying to make more instead of leaving it
Anyways
Shouldnt be to long
Cheers mate, but also in saying that you were selfish, you also did something that im pretty sure a lot of people have always wanted to do but have never had the balls or money to do, run the bitch as hard as it could do and not care about the consiquences, i think a lot of poeple will actually understand that the more you look after the car, the more power can be put into it. In saying that, within reason ha ha.
Damo
After all the Motor Has been through i can say that it is possible to Make 470 RWHP safely on a Street RB25 Standard motor and make it last on Pump Fuel.
To make even more Safer power i recommend Changing the Head Gasket to a Tommie or Cometic and Upgrading Cams in which you wont have to Run as much Ignition Timing and Boost.As for the Bottom end i think that all of it can last.
The main Reasons for the Car making the power is
1) suffiecent intercooler (this is what Makes your Power And makes the Engine last Due to A stable Low Air Temp)
2) the Design Inside the Plenium
3)A Efficent Turbo (there is no need to Get a 1000 hp turbo if all your looking at is 600 engine HP)
4) Great Ignition Setup which is pretty basic and can get even better like the Next setup im doing which runs 6 coils
5) A good ECU
6)Reducing Load Off the Engine EG Clutch fan
7) good Fuel Supply
well done mate its lasted alot longer than the knockers on here had imagined. bout time someone showed em they are keyboard mechanics and dont actually know from there own experience, just from "i heard ..." and "i reckon ..." comments said on forums.
good luck with the new setup
Thanks Mate
I havent commented yet and thats becoz I know f**kall about what destroys a good motor at that amount of power, but its interesting to note that it was No6 that lost compession, as that piston seems to be the one that cops it alot, higher temps and first to lean out, have you accounted for this in the new setup?
And Oh well done I would be happy to have your dyno hours :(
