My server is down @ the Moment
I will have it running next week
And if i got time i want to put all videos on the site
The car is still running and going but has lost comp in that Cylinder which tells me rings as it also has a bit of blow by.
I did richen that Cylinder up by 2 % in the Settings of my ecu but will prob have to run more.
I think it would of lasted if i wasnt trying to make more power yesterday but yeah
The new package will pretty much be setup the Same
the only difference is im going to run 4 % more fuel in that cylinder.i can also muck around with Seperate timing In each cylinder so i will also play with that
Edited by MR331307
15 pages and no pics of broken conrods or holes in blocks. im impresed.
i have a rb30 (n/a convert) on std management and injectors (vl t bits) with meth injection making 253 rwkw witch is a fair achevment in my books now yours is more of an achevement but i dont have the abiliuty to tune mine as i have no dyno. ive been slowly steping up the power to the curent level and now have got the shits sold the thing and am going twin cam head, hope to get 400 hp out of the thing or ill cry.
good job lad. at least u setled down abit and arnt as angry now
Yeah its all good
You gotta keep Calm With some of these Keyboard Mechanics as i have learnt but yeah
Im happy with the Effort in the Motor. I WAS hopeing to get into the 9`z but yeah
gonna have to give up
lol
With the standard motor that is
OK
Here are the photos of the Engine While we are stripping it. The pistons are in Good Condition No detention Marks Or Leaning out Signs EG melting Edges.
The head gasket was a bit Stuffed.As you can see the Standard Cams are there.
Ill post somemore Photos Later and
Ill post Photos of my other Engine While Im putting it Together
With the new built RB25 engine are you changing any of the bolt ons like turbo etc? Also I gather this is more of a drag car then track why did you stick with the RB25 instead of building a RB30 which imo would be better suited to drag only
Edited by Shibby
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
