Hi everyone,
When checking out where the exhaust bolts are that I need to unbolt to change to my new high mount header I noticed that one of the studs was loose. So I tried to tighten it with my fingers but the dam thing came out in my hand. I figure someone had use a breaker bar to do up the head studs and had broken the stud off in the head.
Its the most rear located stud of them all. I might be able to get a drill in there if I remove the ABS gizmo, but even then its going to be a tight fit.
So my latest question is.... should I just buy a head gasket and take the head off to fix this stud issue? or should I try and fix it in the car and risk drilling the stud(possibly off center because you cant see it properly.
I am about to bolt on a GT25 BB 400 turbo and intended on running 20-22lb boost so the head gasket is probably good insurance right? Thus my previous question about the head gaskets...
Any suggestions or advice...?
Cheers,
Ian.
https://www.sau.com.au/forums/topic/106811-broken-exhaust-stud/
Well got it sorted. Going to pull the manifold off tonight and have the a local exhaust shop remove all the studs and replace them with decent high tensile ones.
To the rest of the SAU members.. sorry for this.
Wazz you complete and utter idiot! When are you going to come good on your threats and come and kick my ass! I'm waiting and have been waiting since your "threatening emails" :lol: and frankly i'm bored! I really hope you try because I've been keeping my rage under control and have been needing someone to vent on. You really have no idea who your dealing with. After I leave you a bloddy and broken mess i'll take the $50 from you wallet that you still owe Warren. And because of your emails and your previous history I can do all this in the name of self defence!
Attention Moderators: This idiot called Warick is a known menace and I'm sure he has made is presance felt in the past on this forum. We have had to block him fromt he QLD Street Scene forum becuase he kept using abusive language and ignoring moderators requests to act like an adult. Feel free to give him a red card or block him.
Cheers,
Ian
this is a common skyline fault, i had the same thing, had to have a mobile guys come out and retap and enlarge all studs, plus change them to high tensiel $600 f**king bucks later.
Dam! Though the exhaust shop said it was a 5 hour job if they were going to remove the header, turbo etc. I'll do all that myself and give them the car ready to work on so it will hopefully only take an hour tops to replace all the studs.
I'll let you know how it goes...
CHeers,
Ian
self defense lol
please moderators.. take this cockheads advice.. seeing as he drives a volkswagon.. that is apprently queenslands quickest street registered vw.. yet it has never seen a drag strip before.. so before you go mouthing off PROOVE WAT IT CAN DO YOU COCKHEAD NONE OF THIS TALK TALK TALK SHIT bring it out and proove wat the piece of shit can do and if your really that keen to loose money bring it out cockhead
I had the same thing happen when I blew the gasket between the head and exhaust manifold.
My neighbour (a mechanic) welded a large washer onto what was left of the exhaust stud (in the head) and then welded a nut onto the washer. He had it out in 5 minutes. I'm pretty sure this is what an exhaust shop would do as well. Charging 5 hours for a job like that is a bit iffy. Even if it was a drive-in drive-out job, it should only take a decent workshop 3 or so hours.
Oh....and you two need to get over yourselves............
Edited by Lazy-Bastard
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
