I have not done Oran Park GP since 1984 in my RX3 Street Sedan.
in that case you should probably install me into the zed so i can reel off a few hot laps for you. just to refresh your memory. otherwise you may end up following all those slow GTRs around.
  • Replies 389
Posted Images
Adam, I didn't make your list,,,Is there a problem?.
The weather is 7 degrees here in France,,,should I bring some of it home so John's Zed doesn't overheat?.
Love from Gay-Paris
Neil.
Noooo!!! :)
After I go out and organise a group buy to get a helmet for this day, sign up for SAU membership, prep my car etc... I'm told by work that I have to be in QLD on the weekend of the 29th April! AHH!
Evil bastards!! :)
I hope you guys have a great time. Someone take a camera!
Yeah it's definitely a wait and see with your situation.
Ok the following people have promised to man the flags and I'm holding you to it:
JAS-25T
Silver-Arrowz
Duncan
Kel (by Duncan hehe)
N1GTR
satanic x2
MattSR
These people have said they are definitely in or probably in or something similar but haven't paid:
arm85
SECUR1TY
eugen_syd
Suspense
Trust33 - not looking so likely now though
hanyou
shonen
fatz
J@y
nath95
Primordial
Boosted Zed
R32R
Ok guys, we need to get those payments in. The 29th of April is looming fast and we need to be nice and organised well before so the day runs smoothly.
OH NO! i have something else on that day................................................ sorry Adam.....
Just Kidding mate i'll be there will bells on..............just bells.
just had a word to the missus, shes keen to help out as well if required.
JAS-25T
Silver-Arrowz
Duncan
N1GTR
satanic x2
MattSR
arm85
SECUR1TY
eugen_syd
Suspense
hanyou
shonen
fatz
J@y
nath95
Primordial
Boosted Zed
R32R
Atm this is like a fiasco for me.I may even need to buy new stoppers.Just have to get up off my lazy a$$ to look at the current items.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
