  • Replies 389
Posted Images
Bonks and Maj well well well, the prodical and his son return!
Need to get Fatz there and silver as well.
Paul I'm only doing this so I can have a few beers with you afterwards - long drive back to the Arms though! Come on Fatz - get the Charade out of mothballs. Toulia - borrow your Mum's automatic.
See you all there!
Are you going to make us a movie afterwards doodz?
When was your last oil change BWA? If not too long ago it might be worth waiting til after the track day.
Last oil change was too long ago :thumbsup: my car is probably pissed off with me. Wil is doing it this weekend though.
You're in and I'll hold to that. Thanks.
Can you please email me your full name and phone number so we have a record for CAMS. We wont be selling the details :P
Can any of you other flaggies reading this do the same please.
Thanks everyone.
bob at estc dot net dot au
Can I possibly spectate? :P / amuse myself watching everyone do laps? i'll probably not be driving - but I can't 100% for flag marshall.. hence the spectate (oh and if this was mentioned earlier - I haven't bothered reading pages 2 - 6..)
soo feel free to abuse :D
Edited by Links
rb30 s13 is up and running
im exited
bonkers im comming
Pete - I get very concerned when you mention my name in the same sentence as that "c" word.
Do ya reckon the s13 will pull some decent helis on the hill? don't know if EC has ever recovered from that. It would be good if you could show me the lines around the GP circuit -straight, sideways, 360 degree -whatever.
I am really looking forward to this day.
Adam - can we take passengers? Also can you let us know what the deal is with the extinguishers, do we pick them up on the day, I believe the bolt on to the passenger seat mounts - can you confirm this.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
