Here is a good comarison on what good tyres can do.
S1 best time 1:27.3180 (on Yoka E300 middle of the range street tyre)
S2 Best time 1:22.6884 (on 2nd hand Mich porshe cup slicks)
Same car same day almost 5 sec in time.
  • Replies 389
Posted Images
Hmmm...Love that circuit, so smooooooth ('cept a bit of the north circuit), much more so than Wakefield and a fair bit of EC. Really, really makes me wanna go nutz modding the car to make it better on track days :sigh:
Sorry if I distracted youse all with my flame-thrower! *LOL*
If it's any consellation, my rear bar is f#@cked, hahaha.
P.s Fatz- how much for a RB30 Silvia? That thing was a machine!!
Can i ask where you got the 2nd hand slicks from?
also what size were they?
I currently have 18x9.5 rims with cheap crappy tyres on at the moment. But i would buy a set of R32 GTR rims for the track day and put semi/slicks on if the tyres were affordable
Or maybe some kind person would lend me a set for the day - anyone have spares?
That means if I had been running on slicks, i probably would have been as quick as you in my 13y.o, non-vspec R32, on my first time at OP! :bunny:
...or not.
woah! I've gotta get me some good tyres! :bunny:
ps- your car looked awesome on the track Paul!
I had a friend that run a GT3 in the porche cup last year, they were just sitting around in his garage. The fronts are 18x9 240's and the rears are 18 x 11 290's. The front tyres fit on the original R34 GTR rims, a little small but they do fit. I paid the perfect price $0.
Its like that old saying its not what you know but who you know.
I have about 1-2 track days left on the once I used on Sat and I think I have 3 more pairs of fronts to use after that. Sorry these are not for sale, but when I pick up the rest of them I will try and get some numbes and attempt to source some more for everyone, even if we have to pay $100 per tyre, they would be fantastic for what we do with them.
I will post up if I get any success.
Good time ther Paul L on SLICKS. I ran Hoosier Semi Slicks which are very good although wrong profile as nto enough side wall in rear and wheelspinning a lot as not enough cushion effect I think.
Anyone going to Eastern Creek Next Sunday for Super Sprint? I will there.
Time are here Speed Boat Wins.
http://www.natsoft.com.au/cgi-bin/results....04/2006.ORGP.S2
Apexi AX75F82-P25 Turbo
Apexi GT Spec I/C
Apexi PowerFC
Apexi N1 Coilovers
Noisy Fuel Pump (Unknown)
Bigger Injectors (Unknown)
225rwkw..
etc etc...
It felt pretty good on the day.. my best time was a 1:29.50. My first ever run on a track though, so there is some room for improvement with some decent tyres (Wan Li brand tyres on there at the moment! *Shudder*)
Thanks for the info dude! Very good setup, exactly what I am after! Hopefully will have something very similar in the Cefiro.
Ando
PS Cheers Steve for the PM! :bunny:
Ando
PS Cheers Steve for the PM! :O
you're welcome mate. good luck with the build! there needs to be some more nice ceffies out there! :bunny:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
