  • Replies 68
There is some drag thing on at EC on April 14th and there is an event for the girls - Lipstick Eliminator!!
Any chicks out there interested in attending?
Not sure if i want to enter a chick only event or just throw my lot in with the "street meet" section of the day! Will see how much interest there is :)
Hey Mona,
If you dont get a good turn out on the day and you want to get a couple lady's on the track, please feel free to bring them the the Drag day that i am organising.
go commando!!! sif need gs to run!! hrmp! :)
LOL at go Commando......Hey Mona, you think the guys would mind if i turned up commando ???
Come on girls....no G washing, Waxing, Hair washing/Straightening/Colouring/Cutting, Cleaning, etc etc on the day.....You know you all want to flog the guys :P
As for the guys.....Come on guys......Lets see some entrants......dont tell me the rexy and ford guys are gonna out do you all !!!!! LOL sorry, i can sit on the fence, i got both a nissan and a ford LOL :P...On a serious note, it would be great to see number of you out there.
Should be an AWSOME day, cant wait
....PS, Mona, i think i have been assigned Cheif for the the day, so you may even get to see me with a little apron on LOL :P
Edited by Mr 350Z
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
