Hey guys, after many months of deciding I have come to a conclusion to get R33 GTS-T II.
I want a reliable car so I want it with rather low Ks, anywhere between 50,000 and 100,000 is fine with me.
Ive never bought a car myself and need some advice.
The car will most be used for weekend/night driving and I want it in auto as I want to cruise not go drifting.
Any advice you can give me on buying skylines? I know to do RACV check as well as compression check (do RACV also do compression check, where is it done? how much?) but need to know other details... im bit of a newbie to owning cars so need info!
Plz point me in the right direction if this has been covered shit loads before :D
EDIT: Also Im from Melbourne but in Sydney they got aussiecarcompliance... are they any good? They had some nice looking GTS-Ts go for around 15 grand with 50 k on the clock...
Edited by Sir-D
https://www.sau.com.au/forums/topic/107152-decided-on-r33-gts-t-series-2/
hi there
if you want a skyline, get a manual..
not only would the drive be better, it would be a lot easier to sell than an auto.
RACV? They dont know jack shit. Their inspection is way too general and it depends on ur luck-if you get a good inspector who's really been in the trade for long(and not just any rookie),u're likely ok.
Get the car to a mechanic you know and have him hoist it up and do all the compression checks and perhaps even use a paint tester.
hope it helps. good luck :D
Check out this if you're buying a skyline..
http://www.skylinesaustralia.com/forums/in...showtopic=35129
Also.. it wouldn't hurt to take a friend to look or someone who knows a bit about them to help you look..
    • Yeah nice idea, you mean to suction it to the gauges? I hadn't thought of that.
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
