  • Replies 149
it will be no larger than DIN (ie youll be able to fit in DIN, and may even come with DIN bracket, not sure yet)...around 130x40mm + enclosure size (so maybe add a few mm to each dimension)
20x4 instead of 40x2 (as previous one was too long to fit DIN)...same number of characters
trip meter screen (probably be able to provide this on current displays also via firmware update, but v1 displays need to be sent back for that)
buttons on front rather than top (since front is only side u always want to see, means more mounting positions possible). only 2 buttons (as all menus wrap around, so only need "move cursor right" button
using a switching power supply (more efficient, virtually no heat) so no need for the "blob" in cable like last time
probably (wont know till i do it and if it works):
1) logging to sdcard (read via usb)...this will be tricky though
2) firmware updateable via usb (ie download off net like you would modem/bios etc firmware updates)
3) maybe buzzer or something which could eventually be used for alerts/warnings etc.
4) user control of contrast/brightness
  • 8 months later...
sorry anyone who downloaded it before 5:10pm (GMT+10) today would have got a broken file. should be working now
ECUTalk v1.3.3 - Changes from v1.3.3 beta4 below:
  • #42 Removed console output for few users who have a console setup on their PPC
  • #55 Trip meter sensors shouldn't keep 'counting' while car is turned off
  • #58 Prevent 'clicking' show gauges button with keyboard when gauges already shown
  • #69 PPC users can now utilise the 'working area' option and the LTRB option (ini setting)
  • #70 Changed default 100ms max refresh to 40ms (equivalent of 25fps)
Complete list of changes from v1.3.2 on the Version History page.
this looks great, i've never heard of this free consult software
i only know of PLMS and its $200 (laptop)
how do you suggest we make the required cable as shown here?
http://www.ecutalk.com/diyconsult/
Edited by InterCooL
all you need is a usb/serial consult interface (depending on whether ur laptop has serial port or only usb).
plmsdevelopments.com and blazt.biz both have them
also on ebay there's a blazt one:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...A:IT&ih=008
all you do is turn car on, plug the cable in (make sure u know what com port its using, check out port section in start-run-devmgmt.msc) and then choose the com port in the software and rest should be easy.
the diy cable could only really be made with the diy kit (which ive run out of ages ago), since it has a custom pcb. ill probably get a batch of usb cables done at some point after i finish the consult lcd displays (see group buy forum), probably towards end of year.
  • 1 year later...
ECUTalk v1.3.4 - Changes from v1.3.3 below:
  • #90 Allow user to edit ECU ID for initialisation
  • #93 COM10 and above dont work in ECUTalk
ECUTalk v1.3.5 beta - Changes from v1.3.4 below:
  • #3 User definable warning levels for sensors
  • #99 TB45E engine does not have bank1 injectors, swap with bank2
v1.3.5 beta can be downloaded here: http://www.ecutalk.com/downloads/ECUTalk_v1.3.5_beta.exe
no, pocket pc only. apple are too greedy, they make it far too hard to do something like this on the iphone without paying them a lot of money for the 'priviledge'. if apple dont make money from it they arent interested in allowing it to happen.
unfortuately the newer PPC devices with only a USB connector wont work (need access to actual serial port on it to hook up to consult cable via null modem adaptor).
ones which have a USB host port (which would allow it to host peripheral devices like usb consult cable, keyboards, etc) may work with usb consult cable, but majority of newer devices with mini-usb only dont have this
i think something like toshiba portege g900 has usb host (and found forum post explaining how to install USB drivers for FTDI chip which is used in the ecutalk usb cables)
  • 2 months later...
ECUTalk v1.3.5 beta3 which adds proper support for diesel engines, including diesel specific sensors, also update to error codes.
ECUTalk v1.3.5 beta3 - Changes from v1.3.5 beta1 below:
  • #105 Add extra sequential index column to logging
  • #108 Russian language has trouble changing alert values
  • #109 Add basic compatibility for diesels
  • #110 Differentiate between petrol/diesel (as some sensors are shared)
  • #111 Russian Update error codes (for both petrol and diesel)
v1.3.5 beta3 can be downloaded from latest news post here: http://www.ecutalk.com
hey peter i had a bit of an idea the other day. with the performance tests that you can do, could you set it up so that when you hit the start button, instead of it having a count down timer or whatever it does (been a while since i used it), could you just have it go into a prestage type thing and then have the timer start as soon as you start moving? so just have the timer triggered by the speedo
ecutalk software doesnt have performance tests, you're probably mixing it up with something else.
ecutalk display does, and it works as you describe. you hit start, and once car speed is greater than 0, starts timer till you hit the target. once speed drops to 0 it waits again for next time. i imagine this is how i would do it if i add speed test to the software in future
  • 1 month later...
ECUTalk v1.3.5 beta6 has been released, which heaps of switch/solenoid sensors.
ECUTalk v1.3.5 beta6 - Changes from v1.3.5 beta3 below:
  • #18 Display switch/solenoid etc sensors
Of the added switch sensors, 8 are common to petrol/diesel engines, 39 specific to diesel engines, and 39 specific to petrol engines. Each individual engine only supports a subset of these though, around 10-20 on average. ECUTalk v1.3.5 beta6 can be downloaded from latest news post here: ECUTalk
