HEY FELLAZ!! i got a fairly stock standard skyline 1994 gts-t
witha full exhaust cat back and front dump pipe
standard boost and 235/17 tyres. What times should i expect on the 1/4????
and what should be my next upgrades i got about 7g's and i want to spend it all on the car so yer wot would yew fellaz do (i want a 13.4 pass???
and does anyone run into problems when they boost there stock turbo to 12psi, and installing Aftermarket boost controller, AFC, bigger fuel pump ( is it needed? ) turbo timer
what i want is a ****in fast car so i can kill all those "yobbo" commodores out there plus i want ait to be reliable and be able to drive it to werk.... coz ill ive owned was poxy v8's and their nuthin but trouble....
I NEED HELP GUYZ I GOT TOO MUCH CASH AND I DONT KNOW WOT TO DO!!!!
https://www.sau.com.au/forums/topic/10721-how-fast-am-i/
oh no you beginnning to sound like GTR (see thread about SWOOP):D
what to do? best of getting an advance driving course then progress from there..ain't no money no good if you six feet under matey..;)
cheers..
https://www.sau.com.au/forums/topic/10721-how-fast-am-i/#findComment-173412
Don't do what everyone else would do and go and spend the $7k all at once on big this and big that.
You will end up with lots of small problems and different rated parts that won't suit being put together well.
Mod 1 or 2 parts at a time, tune it, get the most out of it and then continue from their.
https://www.sau.com.au/forums/topic/10721-how-fast-am-i/#findComment-173469
advanced driven course.... cmon dood i can drive...
i had 13.2 bombadoore
and that was sideways all over tha place trust me a skyline is a tad easier to handle hahaha
12's you say!? hmmm yer my target wasnt to get everything HUGE HUGE HUGE but to yer a 12.9 would be choice like anything in the 12's would be great but yer i want the driveability option there too...
https://www.sau.com.au/forums/topic/10721-how-fast-am-i/#findComment-173730
Chino,
The commondore did a 13.2 you say. Was that at the quit motorplex in perth, or have they built a proper drag strip in karratha now?
Gester,
People love doing things the hard way (expensive way). Since chino already has the full exhaust he has got a few dollars out of the way. You can always do 12's by spending lots of money all the same, as long as your happy doing that no one can say you were ripped off because you are smiling.
https://www.sau.com.au/forums/topic/10721-how-fast-am-i/#findComment-174475
Silver gtst,
K&N panel - $90 (wherever)
Thermo exhaust tape - $100 (wherever)
S-afc II - $600 (taka's)
Bleeder - $90 (turbosmart etc..)
Diff cradle kit(KCA349) - $110 (whiteline)
Ogura 4.8kg flywheel - $600 (taka's)
Subtotal = $1590. (should get 12's with just this)
Tyres/ traction --- ANZU Ozrace tyre treatment $40
OR just go over the $2k for some Nitto 555's or similar.
https://www.sau.com.au/forums/topic/10721-how-fast-am-i/#findComment-176897
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
