rb30 crank = shit according to the man building gtr-700 atm at croydon...iono if he wants me to spend 6-8g on a hks crank tho..
could be trying to get me to spend a bit...he said 26 crank is way better
Edited by thizzle
and why is revving higher a good thing? more fricton, more heat, more stress
you dont need to rev the rb30 to 8 grand, thats the point of it.
you can make more power at less rpm, the ideal combination
Go drag your knuckles eleswhere barbarians. Take your slow revving tractor engines, grab your straw hats and flanno shirts and go tractor pulling...push over a few cows while your at it.
The RB30 has never won anything. The RB20 won the ATCC :starwars:
Other then rego and cost, is there a disadvantage...Oh Nissan didnt give it us as a std motor :)
Haha groundhog day for sure. Hey 2BNVS who built your engine if you dont mind me asking? I've been interested in one for a while now, just looking for someone who knows what they are doing and some prices.
Edited by Freeman
ahhaha nice call, who calls 7000rpm high revving anyway, my vs commo almost does that :)
go the high revving engines anyday personally, much more fun when planting out of corners and its hitting the limiter almost str8 away at 9000rpm+ :tongue:
checkout the supra vs mines gtr video and compare the revvy nature, and response/speed the rb26 hits redline compared to the supra 3L, no comparision ;)
sports engine vs torquey engine.
revs rule :(
yes revs rule so throw away these RB motors and fit a motorbike engine!!!! :yes:
Aaaaand (for Roy) there are plenty more bike engines with far more winning pedigree than any rb motor :P
RB20s do suck. I was in a a car with an L28 and it would blow the doors off my car, how old are they again. :confused:
I often wonder what the R32 GTSR would have been like if Nissan didnt invest so much money in the GTR to go Touring Car racing. Would it have had the GTR panels (alloy) with an evolution of the RB20, ie the GTRs solid lifters,6 throttle bodies etc? And kept it rwd to be in line with earlier Nissans which were light, mid power cars... Its a shame they built the thing to go Grp A racing, as i understand that if the capacity had exceeded 2.6L then it woudl have meant either a boost restriction or weight penalty...thats from a grey memory so dotn quote me on that.
I sit back and wait for the new GTR, a car that Nissan/Renaoult are building for a market, not racing. I suspect of the R32 wasnt for racing it would have used an engine bigger then 2.6L
As for talk about RB30s beign truck engines, its kinda funny. You look at M3s, some of the greatest 6 cylinder engiens gettign aroubnd, you read the reviews of its revvy nature etc...yet ppl seem to think dynamically the RB30 cant rev ????
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
