South or North
48 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 281
Posted Images
love your work!
Ps hope you get your clutch sorted mate.
Andrew I saw you in Lindoch :)
No worries mate. I should have got the camera out at checkpoint two when we were the only ones there.
Edited by Whiplash
Another top cruise guys. Was great to meet some people in real life and see some cars that weren't on the Victor Harbor cruise couple months back.
Hope those that got picked up by the po-po didn't get slammed with anything too serious!
Hey Madaz were you the one at Checkpoint 3 that was saying your batteries were flat and the camera kept on turning off? I was the one walking around with the SLR digital camera, if so nice to meet you
well it was easy to spoke me as i had to pull over within 5 min or starting!!!!! ended up by being about 20 min behind everyone, then couldn't catch up as i was stuck behind 3 of the worst drivers eva! so frustrating >: / hopefully next time i can make it the whole way.
ps, don't think the grease will help to much as i reckon its a wire thats loosing connection with the connector. not conter A to B if that makes sense at all. GOin to auto elec tommorrow, see what happens.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
