South or North
48 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 281
Posted Images
Excellent :banana: When do we get to see that clip? Got me waiting now. :P....actually, just found it, good work :)
On that clip was laughing a little, it was after i pulled out that he made the comments :P
lol yeah they werent serioud coments i had a big smile on my face watching you all do it lol, so dont take
those comments seriously :P
All good, realised that after the whistle and then the bit about missing someone behind you guys doing anything. Found it funny, and the stuff about it being on camera :P
Pokies, cheers for the PM, guess i should check them more often rather than 3 times a week :banana:
Oh yeah and by the way, to the guy that was asking me about importing cars from Japan at the footy oval, the website is www.mytrading.org. Mark Hocking :P
Geez....that was my brother again.... he must have been socialising alot lol. I'll let him know for you. Cheers for the site. And thanks to Madaz for the earlier link also. :P
I've got two clips of some nice fast furious action :P But i don't know how to remove the number plates so i won't put them up :P
npz on linky :P
see if u can get those clips too me and ill find a program to blur or take out the plates
npz on linky :P
How do i get them to you? they're off the 4 MP camera i had (the SLR looking one). Still good to watch though. I know that hotmail has a limit on it, and even with the 20MB limit for higher members is too small. Any ideas?
Heslo, i'll get them to you once i find a way of getting em there :P
Edited by DC_GTST
Perhaps host them on an FTP? I can give you details of mine if you wish, all you need is an FTP client to upload to it (FlashFXP, SmartFTP, etc)
Downloaded FlashFXP (Ver. 3.3.5 Beta), how do i exactly set it up in short?
Not hard really, basically all I need to do is give you the IP, Port and username/pass and all you need to do is enter that in the corresponding place (Press F8 to bring up Quick Connect) and then connect and upload your video
Edited by heslo
Looks like a nice turnout, plus was a fantastic day for it. Pity I pulled myself out; but couldnt see myself making the distance, unfortunately. =(
After the Vt Harbor cruise, I pulled up real bad with my knee (again) for some unknown reason, now living on pretty full-on painkillers atm.
I just hope after I have the next surgery I can still drive; it'll be the 7th op on my right knee (ie either take out the kneecap and f*k around some more, or just instruct the Dr to do a full knee joint replacement; he keeps saying Im too young but Im pulling my hair out atm).
Anyone know where I can get the drivers seat rails legally extended backwards?
Cheers, Brendan
Hey guys have you watched the vid?
When i was leaving nuri carpark sounded like my belts or something were slipping.
When ever i boost hard it sounds very high pitch from the engine bay.
Im fairly new to skylines so i dont know what it is
Cheers
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
