The car got T-Boned on the passenger side So pretty much everything is available.
************************This is All that is left********************
*Hybrid copy FMIC $180
*GTR side skirt rhs only $60
*K&N Pod filter and adapter plate $60
*2xPirelli 18" 265's off the back of a ferrari 355 $80each 70%tread
*stock front pipe $30
*stock cat $40
*Boot is fully sound deaded and and is solid $150
*Cheapo pod filter $15
*The SAAS seat i am selling for a mate who wants $300
*I have also cut the rear quarter panel out too, but window is now gone.
*Kingcrome piston ring compressor 60-100mm brand new unopened $25.
Contact me on 0417 125 253 Elliot, or email for more pics at [email protected],
Im situatated N.E. suburbs 30mins from the city(melb)
Edited by KLR32
  • Replies 107
How about selling dump pipe and front pipe from the turbo-back
system? PM me if you're keen. Also pics if possible, and how much
for postage to Mildura Vic 3500? Thanks.
"GTR grill in percect cond with all clips $250" lol u can get em from nissan new 4 dat much.
ill give u $80 for it
what nissan dealer sells them for that much?
are you sure man i priced one a while ago and it was considerably more than 250!!!!!!
Hks cast manifold and wastegate with TO4e turbo with all necessary intake and exhuast piping $2000 (cost $1100 at jpc 2 months ago just to get the intake and dump piping done)
What power were you making with that turbo set up? Do you know what its rated at?
Could be interested.
Cheers.
Will you separate the wheels onto pairs? I'm looking for just 2 wheels. Do they come with tyres?
Also, what kind of clutch and how much power will it take?
thanks,
Russell
I'll be selling the dump pipe with the turbo kit as i had it made to suit the low mount hks manifold. As for the front pipe its 3" stainless $100, but not 100% sure it its still straight.
I'm interested in the whole exhaust, pics would be great? Any ideas on postage to Adelaide 5022.
Sorry not willing to post any items atm especially interstate unless small.
Cheers.
i never had it dynoed but around 190rwkw on 13psi, but the guy i bought it ran a low 12 in a vl, but all i've heard is that there rated around 440hp.
thanks,
Russell
clutch is rated at 240rwkw
Pics of front pipe to [email protected]
Also, I'm in Mildura Vic 3500, so postage shouldn't be much of a problem or cost much at all. Want to make sure it's still straight tho! :D
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
