Hi Dudes,
After selling my HKS BOV with excellent responses from you (many thanks to those who have submitted an offer) , I have decided to clean out my garage and sell the rest of Skyline parts. These were all previously from my Skyline R33 and worked perfectly fine.
Why selling? Mate, I am getting married soon. After pressures from different people, decided to drive a 4 door car now. Yeah sucks huh. I love my skyline so much and so spent heaps $$$ on it. But still wanna say SKYLINE RULES :)
Basic rules apply, HIGHEST OFFER GET THE PARTS... the part is selling individually...buyer pays for shipping, COD, Bank Deposit, Pickup available for Melbourne Skyline mates, what you see is what you get.....
1. 400R Modified Front Bar (Gunmentral grey)
I modified the center bottome bit, which put allows more air flow to go into my large intercooler, which was front-mounted. It's freshly painted and put on my car for less than a month before taking off from my car.
2. Original air box (Min. $120)
This is ABSOLUTELY hard to find. Otherwise you can try to find it at wreckers. I think the air filter is after market as you can see it's green.
3. Potenza Suspension System (Min. $400)
These 4 (2 front + 2 rear) will low your car to a nice and reasonable height. It's original from Japan. Like you, i can't find Potenza suspension kit in Aus too.
4. RS Cat back exhaust pipe 2 pieces
The width of the muffler is 110mm and the pipe ... not sure.. but you can see it from the picture
5. Cusco Oil Catch Tank (Min. $70)
well.. nothing else I can say.
6. Original Intercooler with a pipe
This is an original intercooler for R33, sell with the pipe in the picture.
PS. I got a old HKS F-Con Computer with control unit. I don't have picture here cos it's still in my car. But I will ask my mechanic to remove it....if you are interested, let me know. ... This things really surprise me. Why? cos standard skyline, you drive it, yeah you can feel heaps power from the wheel, but at the same time, you can feel the car is fairly heavy too. After I have install it, I can feel it's much lighter. Well...better keep it short.... once I remove it I can share more of my experience with you.
Well that all, got any questions, feel free to ask me.
Cheers
Patrick
https://www.sau.com.au/forums/topic/107989-skyline-parts-garage-sale/
how much u want for hte front bar?
do u have any pics of it on the car?
Oh and will it fit a series 1 r33
Musky :D
Here's the picture when the suspension and front bar fitted. Of course you can see the gap between the bottom bit and the intercooler... so I modified it with Fibre glass and close that gap there and can attract more air flows to the intercooler..
I am looking at anything above $120.. I am happy to sell it. of course shipping is on top of that.
Unfortunately this sit is NOT E'bay, if you want to auction them off i suggest you go to the ebay site.
As per forum rules, please specify price and negotiate from there.
Sorry mate, I wasn't aware of that rule. Won't do it again.
ill offer ya 50 for the f-con.... cause ill need to find some one in adelaide to tune it for my rb20....
from wot i gather there arent amy people in the southern states that know how to tune these properly
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
