Hey players, I am thinking about upgrading my turbo (in my R32 GTS-t) before the doc comes and just wanted an opinion...
I don't want to spent too much and don't want much if any extra lag...
From what I know the r33 turbo gives better flow and is a cheap option (there are a few low k jobbies for sale for around $200). Can anyone tell me the expected benifits (added power) and will it withstand higher boost than the RB20 turbo (I am currently running aroung 13-14)...
OR, can you reccomend another turbo that would be a better option and around the same price range?
I know it will be best to get something serious but that wont happen before it gets tuned so I figue if I get something for about $200-$300 and can gain another 10-20 because of it then it will be worthwhile.
For those of you who don't know my other engine mods are...
3" Turbo Back Exhaust
POD Air Filter (cold air intake)
Front Mount Intercooler
Gizzmo Electronic Boost Controller (13-14psi)
Bosch 040 Fuel Pump
I hope to get a Z32 AFM before the tune but don't know about that!!!
Thanks!
Todd
https://www.sau.com.au/forums/topic/107996-turbo-upgrade-help/
i have recently gone to a rb25 turbo on my car and have noticed a huge difference. I gota bit more lag but up top is just awsome, i run 10PSI and it pulls all the way through the revs and is much better than the rb20. Only problem was i didnt get the turbo elbow so mine is still a bit restrictive and needs a tune. I say go for it :) and its just bolt off and on too
Thanks mate... which bit is the turbo elbow? (turbo to filter??) and why does it differ from the rb20 turbo??
Did you get new gaskets? Why did you change it? (just for upgrade or did you have a stuffed turbo?)
Thanks! Todd
  • 1 month later...
The turbo elbow is the part that heads back towards the intercooler, the rb20 one has a slightly smaller hole.
Mine pulls a bit harder through the revs too, im running around 12psi, but the only other mod i have is an apexi pod filter, and its auto so its quite restrictive.
Wind the boost up to 13-14psi ronald, you might as well its not gonna hurt the turbo.
An R33 RB25 turbo with replacment steel turbine wheel - 3", intercooler, ecu ect it would be good for 200ishkWs 16-18psi depending on tune. Thats a similae set up to most of the GTSts on the track.
If your after budget new why not consider a KKR - 210kW at the wheels with 11.5psi. You'd buy on new for early $800s.
Thanks Stu, is something to consider but was trying to avoud spending over the 500 mark... looks like I will be wasting my money if I dont!
I ended up getting 135rwkw after my tune on 13psi. (POD, FMIC, 3" Ex)
I just have to get a new turbo and fit everything (GTR Injectors, z32 AFM, High-mount manifold and screamer pipe) and I will take a trip to Vic to visit Sam for a retune! Can't wait but if I am forking out $800 for the turbo I will be waiting a little longer!
Anyone want to buy a go-kart? ;)
Yeah with everything else you have on the car its almost a waste not to wait and get a good turbo.
I would personally go for a rebuilt RB25 turbo, its a proven product and unlike the KKR is a very simple fit.
Providing whoever you source it from knows what they are doing you will not suffer much lag either.
Eitherway, going from 135 to 200 will be an un-real feeling... for atleast a few weeks until you want more again!
yeah, can't wait!! I was a little dissapointed with 135 but really isn't too bad on 13psi (plus the fuel ratios are are on the knocker now and I gained about 20kw throughout the rev range!) but I am running 14-15psi now ;) but hey, I am getting a new turbo :O
How much should I expect to find an R33 turbo with steel wheels for?
I tried running 14Psi of boost at the drag day, but my car doesnt like it and hits the limiter lol. Once thats taken care of with a tune, i might bump it up a bit more
Obviously your computer still has a boost cut then, i would suggest not to run anymore than 13psi through a ceramic wheeled turbo....
i still have the speed cut too :)
looks like you should have had your car tuned when dr drift came down.
I believe you can send him your ECU and he will remap it without tuning it... will be alot better but not as good as a full dyno tune. Plus it removes boost and speed cut... (and rev limiter if you so wish but not reccomended!)
My Air Fuel ratios are spot on now too and am getting a lot more k's for my $$ - will pay for itself in the end!
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
