Sick of this stuff getting in the way.
RB25DE engine block complete with crank, rods, pistons, oil pump and bottom pulley. (I think this block would be suitable for turbo as it has the oil & water plugs in the side)
Crank angle sensor, 2 x sets of coil packs, fuel rail, injectors (270) loom for same. water pump, VL Turbo Oil Pump, Standard inlet manifold, cam pulley covers, some alloy piping, (thermostat cover) starter motors & maybe more.
You looking for something, ask?
Make me a reasonable offer on any or all and it's in the mail, or pick it up.
Guess engine block should be picked up.
FIRST IN BEST DRESSED
https://www.sau.com.au/forums/topic/108068-rb25-parts-clearout/
got the engine cover? is it the same as a gts-t?
What do you call the engine cover?
The top piece that goes between the cam covers or the front that covers the pulleys & timing belt?
  • 1 month later...
