If he strips it, i need parts.........incase you know who ownes it?
It was an Autostyle car and went home on one of there trucks. wo maybe contact them, I'd say it's repairable though, it was just the front that hit it was another 'turn 4' victim I'm told (can't be 100% sure though as i didn't see it happen, only the aftermath :huh:
wooops.. when did that happen..
was hoping the forza evo 9 was gonna get in on the street drags..
don't worry ben - he was still out today drifting hard.. if it was the 180sx your talkin about.. had the silver rear lights..
http://www.autostyle.com.au/cars_engine.asp
search on nissan, bottom car :huh:
Edited by Links
Hey guys what a weekend that was...i was a competitor but didnt drag or anything just tore it round the track most of the weekend...
Definate highlight was the R32 ripping the V8's to shreds...me oricle and a few others were at the pits watching all the V8 guys getting pissed off cause they kept losing hehehe...
And im still crying over that GTR that crashed :D cant believe that
also - who was the photographer you were talking with out there.. wondering if he's got a website?.. wouldn't mind seeing some of the photos..
Nope. I don't have a website. :D Picking up all the photos this afternoon from the boss and will put some up here.
BU5TER performed very well and was one of the VERY few cars that was raped hard all weekend.
Adrian
Nope. I don't have a website. :) Picking up all the photos this afternoon from the boss and will put some up here.
Adrian
Who says it was you Adrian :O
I had a quick look under the hood of the white R32 GTR that was running there. Was very nice indeed. He was running 283 degree cams, no wonder that thing moved!!
BU5TER - what are you running in your car cause you could hear your turbos wind up a mile away?
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
