  • Replies 64
Miko has a 2200lbs pressure plate, if that. It might even be 2000lbs. After driving a load of cars with 2500lb clutches I can assure you Miko's isn't 2500lb.
Try Rob's clutch before you decide. You won't even need to start the car to see what I mean. They are leg breakers.
okies i'll have a chat to Ross.
edit: righto just called Ross
yeah the 2500lb is a tad heavy but should hold 400hp
the 2000-2200lb which is in Micko's (correct u were rev) should hold 350hp and is much easier to drive.
this is with the DCB clutch plate (9 finger purple)
with the organic 9 finger jobs he said your better off with 2500lb pressure plate as then it will hold the 350hp but the 2000-2200lb may or may not hold it.
Troy/rev,
I drove Rob's car last night, and while I ddin't find it heavy in the slightest, maybe I'm too used to my twin and 4-puck, I must admit I didn't like the take up. It was most annoying to drive, even a short distance, so I would check what your getting and perhaps drive a car with it in first, cause you will be stuck with it for a long time.
See'ya:burnout:
Yeh, horses mouth sounds like the idea....
Just gotta get some fold behind me, then i'll go talk the sphincter of the universe with Ross.
But just wanna know a rough cost of _just_ the clutch, not the pressure plate job ?
rev210: What's the reason you only replaced the clutch, and not the pressure plate ?
Yes you are probably right , I think it was a 2000-2200 lb pressure plate in Micko's and mine.
What makes it easy with the GTR is the vacuum assisted clutch.
Do the R33 GTST 's have that ??
Cheers
Ken
Well its installed.... I got the 2000 Pressure plate, my initial feeling is that is nice and easy to drive, its easy on my leg and doesnt slip.... I just have to get used to the new friction point ( much much lower down on the pedal ) but that is going to happen with any new clutch...
Overall very happy.... I have already started on the approx 200k's of running it in...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
