  • Replies 42
Thanks Karen, just remember your help was pivitol in me getting this job.
Big, no HUGE thanks to all these guys too:
SMR33
Charly
Squizz
Sciby
v8skylineman
Bunta
impact_blue
Revhead
and everyone here on Skylines Australia!
Without your invaluable help and advise I would not be in this position right here, and there is not enough money in the world to be able to compensate you all to what I think you ought to have!
So, who is up for a cruise to Rocky? SERIOUS!
We'd be in for a cruise. SERIOUS! I have rellies in Rocky & mates in Gladstone, so it'd be a good time to visit them (plus there's a Bad Girls there) - w00t! SAU Strip Club Cruise!!! :)
Well it will most probably be on the weekend of the 25th and 26th. I dont have a problem if you want to come up with us!
Anyone else want to tag along?
Enjoy Cy. My wife goes to CQU (External Student obviously) and will be up there for live-in week in a couple of weeks also!! Hope the job and lifestyle are all you want and deserve.
And NO, I don't think Rocky is ready for Ska!!!!
ha ha good ol rockholeton you'll enjoy it for about a day or so. i lived there before coming to brisbane, make sure you go out on thurs night check out all the speed racers..
http://www.cdsninc.net/index.php this is there local forum.
Cheers for the restecp people! I will miss all of you anal dwelling butt monkeys! Guess there will be plenty more in Rocky :laugh:
We have lived out in Emerald before so Rocky cany be any worse than that! And if it is, meh the increase in salary means we could afford to fly down maybe once a quarter, save up all my RDO's and take a week off :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
