Anyone going to the MCCR meet tomorrow Night?
  • Replies 61
i got his numba as well his names BiBi or sumfin like that ... I wanted to get his car for that photoshoot we been tryin to pull off.
Seemed like a nice guy, altho i dunno bout his parkin skills (takin up 3 spots lol)
Originally posted by MzDfectd
the driver of HOTLNE is just as hot as the car!!
fwoarr mmmmmm
is that that chick standing behind it??
who is jetr.34??
looks lice.. full bomex bodykit...
sorry i got JETR34's numba, not HotLne... most of my mates for sum reason dun like hotlne coz he's got a "mines betta than thou" attitude. I've neva met him so I dunno.
JETR34 is a R34 GT-t with a full bomex aero.
if ur talking about the card shoot it would look better with a darker coloured R34 rather than a bright yellow one.
dales one would suit it more... plus we dont want anything too out there in it... want them as they come so to speak
JETR34 is my mate ibi
hes on these forums but doesnt post
remember i posted up a thread trying to sell his plates
well he finally got the car and kept the plates
very nice liner!!
HOTLNE is a nice guy stop bitching children!!!
oh did i mention hes spunky.. ooohhhhh
/me grinz
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
