hey guys i've had enough. car's for sale. $15,000 firm no rego no rwc.
vehicle is:
1991 Nissan 180sx black in colour.
Engine: Arias 40 thou oversized forged pistons (has 1200 k's on the motor total) new timing chain and oil pump water pump and thermostat
Scat I-beam rods
Clevite race bearings with standard crank machined to match
O-ringed block
tripple layer metal head gasket
Tomei rocker stopper kit
ARP - rod bolts, head stud kit, bearing retainer kit etc....
ported and flowed head ----------- REBUILD COST ME $8,000
450cc gtr injectors in custom railrising rate fuel pressure regulator
Greddy drift sump
cusco catch can
cusco coil overs (HEIGHT ADJUSTABLE)
5 puck custom clutch
five stud conversion wiith sumitomo front 4-spot calipers
290mm slotted and cross drilled rotors
front camber tops
safety 21 half cage
G REDDY T518z turbo with custom flowing on the front cover.
Trust GTR style intercooler with custom powder coated piping - blue
all hose clamps are high pressure truck type clamps, with new silicone joints.
x-force extractors (stainless)
trust front front pipe
x-force dump pipe
x-force cat back 3-5 inch exhaust.
fixed position drivers seat
nardi steering wheel
razo pedals
hks turbo timer
Turbo smart eboost 1
r32 gtst rims and second hand tyres - its a drift car dammit
type x front bar - f**ked
NIsmo side skirts -
******* one door is in primer at the moment can and will paint on request.
if you respray the vehicle and do some other tidying up = instant show car/drift car
Vehicle has a total of 101,000 k's on the chasis.
estimated power somewhere between 350 - 400hp at the wheels on 19 psi
call Shauno on 0424534691 or
also have a power fc and hand controller for the vehcile as well not fitted and not included but can be purchased seperatly for $1,100.
Also have 18 x 8.5 and 18 x 9.5 inch star corp racing wheels slight drift damage to one, completly rooted tyres on these. $1000
plus i have assorted rear trim parts if you want them you can have those
sorry i don't have any photos on me at the moment
https://www.sau.com.au/forums/topic/108780-cheap-bombed-180sx/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
