  • Replies 159
Where exactly is the BP that we are supposed to meet up at? Can i get some directions please?
The BP(travel center) is on the north bound side of the Bruce hwy. just head to the sunny coast from brissy, you can't miss it!
maps/instructions are printed and ready to go. cruise is 148.9km with a break halfway near Malaney, so even the thirstiest of GT-R's should make it no worries. We've got a good variety of roads through some nice country - should be a good day. i know I'm looking forward to it.
For anyone coming from Brisbane, those major roadworks at Burpengary just before the Morayfield BP and still happening. They almost always cause delays, often traffic comes to a standstill there, so allow an extra 10-15 minutes to get there in time.
For the BBQ I will we need Volinteers for cooking-bringing food-Drinks-admin(collecting moneys/entrys)-route design etc.
I am sure that I have missed something if so let me know
Volinteer list
Admin----------------------=Nessie (baysidebluebnr34)
Route design--------------=Hrd-hr30
Route design--------------=Baysidebluebnr34
Sausages------------------=Baysidebluebnr34
Drinks---------------------=Baysidebluebnr34
Bread----------------------=Lunatikk
Onion----------------------=Lunatikk
Oil and utensils-----------=Baysidebluebnr34
utensils--------------------=spook
Sauce (BBQ & Tomato)--=Arbess
Cook-----------------------=Baysidebluebnr34
Cook-----------------------=Variable
Cook-----------------------=spook
More cooks please
Edited by Baysidebluebnr34
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
