First up...
Slap the stock hsf back on it with only a light smear of goop. Use your finger to slightly smear it across the top of the cpu so that you only 'just' can't see the heat spreader.
Boot the system, jump in to the bios and check the cpu temperature and voltages. Ensure they are all within spec.
Do you have a multimeter?
With the power on shove the neg in to the black 24/20pin m/board plug.
Then carefully check: (hold for 5secs or so)
Yellow - 12v
Red - 5v
Orange - 3.3v
If they come up fine give the fan header a quick check.
Failing that.. Swap cpu's out, if all's dandy then the cpu is buggered. :(
I tend to doubt the cpu is buggered UNLESS you have left the cpu on when its had overheating issues. A quick blast at 75-90 odd degree's the cpu will handle.
When the system is fixed... Stress the bugger using Prime95 and or 3dmark etc.. hammer the system.
While its being hammered grab the multimeter and check the voltage drop, there should be next to no voltage drop.
IF voltages drop out of spec replace the psu. A voltage drop of 0.01-0.02v I think is acceptable.
Good idea Cubes, will wack back on the old hsf (damned noisy, like shes on boost lol, hence why I had to replace it, was giving me a daily headache here at work) and try that. Dont have a multimeter unfortunately.
Cant get to bios as the screen wont hook up, PC starts, then restarts, then restarts, etc etc etc. Got a plan of attack for this weekend (retest with stnd hsf, retest with different cpu chip, etc) so we'll see where it takes me.
As for highflows, how about chatting to Adelaide Turbo Services, Paul? Pixl8r got a GT30 highflow from them for his Stagea.....
Think I scratched the back of the mainboard when I installed the big arsed cpu fan. May have shaggd the mainboard, will know moe over the weekend.
Ummmm, does anyone know what cpu chips are compatible in a Gigabyte GA-8I915P-D Pro mainboard? Currently using a Intel Pentium 4 775 3.4 ghz 650 chip (home pc). What is compatible with the 600-series chips (630 = 3.0, 640 = 3.2, 650 = 3.4, 660 = 3.6)? Some type of Prescott.
If Ive shagged the mainboard of the work PC (EliteGroup L4S5MG3, with Pentium 4 775 3.2 ghz 640 chip), then work can have my GA unit and I'll get a new SLI mainboard for the home pc. If its the cpu thats gone I'll be after a replacement on Monday - Im sure some of the Prescott series can be used but unsure of what model.......
Cheers mate, lol, I used it all !! doh. Thanks for the information, that is very kind of you.
did u not read the instructions :(
all HSF assembelies come with paste allready smeared on them this is fine for running a computer with minor overclocking
most 775 CPU under Pentium D are fine for that motherboard ie: all 6** series will work and all the Extreme Edition also see Here for product information
well i bought a thermaltake from IT warehouse and that had it on TR2-M13 SE for referance
not to worry
you dont even really need to smear it because one you put fan on and clip it down that pressure will spread it out
edit
look @ pics here no thermal paste but it was there when i bought it
http://www.tr2tt.com/products/coolers/m13se/m13se.htm
Edited by Madaz
Not all.. i use fac alpha heatsinks, and they don't pre-apply them. Also the use of pre-applied thermal pads was discouraged after what happened to many exploding socket A amd chips a few years ago.
edit
You smear it because on an un-lapped heatsink you can end up with an uneven distribution of thermal paste. I recently repaired nozilla's laptop which had this problem, the hsf was mounted in such a way that there was blotchy paste distribution... that caused a tiny hotspot right in the core of the cpu and pretty much fried it. I've got pics to show you what i mean. It doesn't happen often, but if your hsf is not properly lapped then i wouldn't chance it.
Golden Orb was clean, ie no goop, and there were 3 basic picture instructions. Wasnt much goop, but obviously enough to go out, down and into the cpu chip area, seeing that I didnt spread it out but let the pressure spread it across when the fan was screwed down.
Cheers for the link Madaz, was on that page a little earlier but me silly ol'brain (at work, busy as per the norm) didnt register the cpu list was there, yeah I was sure the Pentium D Prescott range worked as well, thanks for the info lads.
argh if you didn't perfectly spread the thermal paste (=goop) over the CPU, then you have DEFINITELY fried the CPU. You would only need the smallest hot spot for a fraction of a second to fry an Intel CPU. Never, ever, ever just let the pressure of heatsink application spread the goop, as it is NEVER perfectly even.
Dude you really should have gotten a tech like Howie (or even myself) to do it for you - there is a reason guys go to Uni to learn how to fix computers :(
And like Howie said - noone should EVER use the crap that comes with heatsinks or even worse pre-applied to heatsinks - get some good stuff - I always use Arctic Silver 5 these days
Uni are still teching Ada and Sun systems.
Uni for IT is really a waste of time unless you want to work in defense. A 4 or 5 year course garanties everything you learnt in the first year is out of date by the time you have finished. It has applications later on for pure research but not a lot of use in day to day IT
Didnt I just say i am going to ATS and bill there is hooking me up with a sweet GT30R kit?
On the side of CPUs,
up the c2d's
that is so f**ken true.. im using that as an excuse.
I didn't learn any Ada or Sun systems in my B.I.T course. :(
All the hardware side of things (assembly, low level inner workings right down to chip design etc), Linux, Windows, a little dos, a LOT of java, c (I've always liked c), mysql, php, javascript, hex/binary, a LOT of project management a nice slab on networking/internet/protocols, quite a lot of psychology (body language, handling situations/discussions, interpersonal skills, personel selection, and... lol child, abnormal etc psychology) etc... Really too much to list off the top of my head. :P
The psychology was really quite interesting but the research reports. argg. :nuke:
At uni the Sun systems are only used for topics that require the server/linux side of things. (webserver, mysql ..........) Apart from linux, we learnt nothing of the 'sun' system.
The course has recently been tweaked a little to drop a lot of the useless psychology (child, abnormal etc) to include statistics/data analysis etc that is far more relevant to I.T.
I didn't learn any Ada or Sun systems in my B.I.T course. :P
Then Im glad to see they have finally updated the courses.
Cubes, you are/were studying at Flinders? (my experience is with Adelaide Uni - perhaps I should have qualified myself)
At the time (and to a lesser exent even today) Flinders hasnt got the same reputation as Adelaide (its the old school tie bit not the courses) and most industry contacts I have (other than Dpt. Defence and CSIRO)dont consider a degree in IT worth much without time in the field or even some TAFE units behind you.
For many people its more relevent and offers better employment and renumeration prospects to do the MSCE and CISCO units than a degree in ICT. (IMHO and many others)
Yes it was at Flinders.
You are right it is the old school tie bit.
Networking is what I like so yes Cisco courses is where its at.
Most of the decent jobs *not helpdesk/sales* advertised require some form of tertiary qualification. Simple 'experience' just isn't enough UNLESS you are older and have years of experience behind you. Even then the majority of those do have a qualification.
I can see where you are coming from Guy, but I am talking ground level things like Joel said - even simple things like ALWAYS wearing an electrostatic wrist strap EVERY time you touch a computer - I see professionals even not doing this and zapping things from time to time.
I sold a brand new AGP video card on Ebay a little while ago (tested it was not DOA before I posted it) and the little prick that bought it zapped it when putting it in his machine. He screamed blue murder I had sold him a faulty card etc and when I asked him if he was wearing an electrostatic wrist strap he asked what one was. I told him to go screw himself.
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
