neapolitan i love strawberry vanilla ands chocolate ice cream
siff turn my thread into a flame fest
1) its not my computer
2) im lucky to get on a computer @ lunch otherwise i would have to use my phone to browse the forums
3) pauly is still a noob
pfft we all know neapolitan is only goods fer the chocolate which gets eaten first.
Nuts about chocolate by dairy bell FTW.
Back on topic though thought id add this fer a few who havent seen it (i hadnt) - http://www.ted.com/index.php/talks/view/id/129
+1 paully being a noob. :O
Edited by Bl4cK32
do you have nothing but flames to add to this board Pauly
cause that seems like all you do then you complain when the big boys gang up on you
maybe i should get the geforce 4600 ti out of the shed and glue them together have a monster card like your to play C&C with /blatant
sorry madaz, ppl love me i know, but some just have to accept that at times i can be a c**t.
this is the wasteland, hence why im being slightly over arrogant, sorry if i offend.
Edited by Pauly33GTS-t
Just got Hospital Tycoon, reliving the old memories of Theme Hospital, that was a GREAT game, this isn't too bad either
huh, i just checked and hospital tycoon isn't out until the 13th of july.
unless it's already on torrents.
    • How do you propose I cable tie this: To something securely? Is it really just a case of finding a couple of holes and ziptying it there so it never goes flying or starts dangling around, more or less? Then run a 1/8 BSP Female to [hose adapter of choice?/AN?] and then the opposing fitting at the bush-into-oil-block end? being the hose-into-realistically likely a 1/8 BSP male) Is this going to provide any real benefit over using a stainless/steel 1/4 to 1/8 BSP reducing bush?
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
