neapolitan i love strawberry vanilla ands chocolate ice cream
siff turn my thread into a flame fest
1) its not my computer
2) im lucky to get on a computer @ lunch otherwise i would have to use my phone to browse the forums
3) pauly is still a noob
pfft we all know neapolitan is only goods fer the chocolate which gets eaten first.
Nuts about chocolate by dairy bell FTW.
Back on topic though thought id add this fer a few who havent seen it (i hadnt) - http://www.ted.com/index.php/talks/view/id/129
+1 paully being a noob. :O
Edited by Bl4cK32
do you have nothing but flames to add to this board Pauly
cause that seems like all you do then you complain when the big boys gang up on you
maybe i should get the geforce 4600 ti out of the shed and glue them together have a monster card like your to play C&C with /blatant
sorry madaz, ppl love me i know, but some just have to accept that at times i can be a c**t.
this is the wasteland, hence why im being slightly over arrogant, sorry if i offend.
Edited by Pauly33GTS-t
Just got Hospital Tycoon, reliving the old memories of Theme Hospital, that was a GREAT game, this isn't too bad either
huh, i just checked and hospital tycoon isn't out until the 13th of july.
unless it's already on torrents.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
