My computer randomly shuts down for no apparent reason either.
It's either motherboard or cpu as i've i've tested everything else.
I hate pc's as it means to fix it realistically i need new RAM, motherboard, and cpu, powersuply
It never usually happens to me but I have noticed that upon new OS install it does it maybe 4-5 times then it becomes completely stable, it must be patches or something that fixes it.
I am now running 64bit winxp pro and I must say significantly quiker than vanilla xp pro.
Well i seem to of fixed my wireless woes.
I got another wireless adaptor. A linksys one.
I now get excellent signal strength and no dropouts what so ever.
Also my computer seems to boot in half the time and is more stable.
I'm guessing that the netgear wire;ess adaptor just didn't agree with my hardware and/or drivers.
Everything was up to date, including firmware on everything.
Ohh well all good now.
Also fishpaste someone from your work rang me today.
Do you guys have any games in stock at all? or is that not really your area?
someone is pulling some kinda random insurance job thing and wanted quotes on crap
have to ask the boss about games, we normally get copies of the new big titles when they come out, but other than that, we dont get much demand for them
nice score Chops
I gotta say that Im *finally* happy with my Xpertvision 2900xt 512mb from MSY Adelaide.
better performance and quality in my mind then 2x 256mb MSI 7800gtx in sli mode
.......... just awaiting my Vista Ultimate I scored for under $250 on ebay and Im set :)
LOL
hahaha oh well, atm my broadband is so bad I cant even access this webpage at home.
churning to Internode as we speak.
never mind, OEM Vista Ultimate 64-bit for 235 + delivery, guaranteed new and unopened. saw it in harvey norman for $700 odd
crazy
my current XPpro is a dodgy copy. so I guess its time to do the "right" thing
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
