I think you're still looking around the 1100 - 1300 dollar mark.
I get the feeling though that some time in the future sony may release a fully software emulation of the ps2 hardware for ps3. And then you won't need to get a 60gig. Thats just a bit of an eduated guess.
so its true you cant play ps2 games on a 40gb ps3 :rofl: i thought that sounded fishy but hey we are talking about sony
i got a feeling a chip is on the way letting u play copied/downloaded games as well as PS2 games...maybe more :yes:
query:
Q6600 @ 3.60 ghz (2.4 stock) G0 stepping model
2900xt (two-off) with coolermaster glacier-600 water cooling
thermaltake bigwater 735
70degrees core 0, 69 core 1, 67 core 2, 66 core 3
on full load
is that too hot?
bearing in mind the graphics cards idle at 49degrees
runs at 47-44deg on idle
pump - cpu - pcie - pcie - radiator - reservoir - pump
had a nth bridge water block as well, but not on atm
might have to refit it along with the double radiator - just that the extra radiator has to sit outside the case :)
Yeah man that is WAY too hot for a water cooling system. I would turn your voltage down a tad - but you may have to lower your fsb too. What voltage are you currently running? I would think around 3.8v, which is probably too hot. Your CPU won't have too longer life at that rate. 44 degrees is way too hot at idle too.
Should not even be that hot with a really good heatsink and fan.
Put more case fans in and get more air flow will cool it down heaps. I have 2 x intake and 2 x outlet fans, plus the CPU, VGA card and dual PSU fans. There is no such things as too much air movement. Is the fan working properly on your radiator? I think it may not be - that would be your problem.
yeah thought so
better rejig it and add the external double radiator/fan system (its a 745 system, but only setup the small single radiator)
the 2900xt's used to see 100degrees on air (stock) on load, so the water has brought them down by 35degrees
    • They are in fact just nozzles. They are there only to produce a spray pattern and limit flow. The injector itself is what I use to control flow to the 7x nozzles. My old system had no injector and only PWM the pump. This lead to a lot of inconsistencies, and poor atomization at low pressure when the pump was ramping up.
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
