Andrew, unfrotunately no I can't get you a key :D I was one of the first 2000 to activate my beta key when Kane's Wrath was released, hence how I got in. You are welcome to come round for a gander if you wish... Might even be able to hook you up with my key for you to play, so long as you aren't on when I want to get on :worship:
Managed to become part of the Red Alert 3 beta for anyone who cares. Pretty fun and the whole naval base building adds a whole new twist to things, pretty good so far IMO
ey mate yea i got in to, havnt started playin yet have been busy building some computers for people. Hopefully get onto it on the weekend. How is it any good??
guys what do you think of this build??
i've had my pc for over 3 years now and i think it's time for an upgrade. i figure i'll keep the same case, burner, keyboard, mouse, and probably move a hdd over.
please tell me asap as i'll go pick it up from all needs in the morning.
GA-EP45-DS4P $191
INTEL E8500 $210
WD WD6400KS 640 GB $94
cORSAIR TWIN2X4096-6400c5 4GB $139
Thermaltake TR2 RX 550W $97
Gigabyte HD4870 512mb $366
ohh also am i able to take my current vista home premium OEM and install in on the new pc without any hassles? what i mean is will it still activate as it's a totally different pc or will it be all good?
thanks.
GA-EP45-DS4P $191
INTEL E8500 $210
thanks.
parts are fine , only thing id change is the PSU , get a corsair HX620 , better quality and it is modular
GA-EP45-DS4P $191
INTEL E8500 $210
Nice setup apart from the PSU.
Corsair or Seasonic PSU. They are the same thing.
The 640AAKS is a very quick drive. :blink:
Hmm went and bought it all on Saturday along with a 21.6 inch samsung monitor.
Awesome setup love it.
Also decided to get two of the hdd and am running them in RAID0 muhhaahaha so fast.
On the case of the power supply it is modular, and it seems to have more than enough juice for everything so far.
Crysis at 1650x1080 everything set to "High" and i get a constant framerate of 45-50.
^^^ That's an awesome rig you've put together, it's near identical to mine :)
GA-EP45-DS3R
Intel C2D E8400
Seagate 7200.11 500GB+750GB
OCZ Platinum 8500 (1066Mhz) 4GB
Seasonic S12+ 650W PSU
Nvidia GB 8800GS -> soon to be HD4870 of some sort
im running this on my desktop... got a couple others about but this one is slightly moar interesting
GA-M56S-S3
AMD X2 6000+
Kingston 1G 800 (four of em)
Gigabyte 8800gt (512)
WD 1TB 7200 (got three of em)
WD Raptor 150G (bootdrive)
Antec Neo Power 550W
also have two LG W2252TQ's (22" widescreen 2ms)
gonna get better ram next
any suggestions?
Sticking with the stock frequencies for your mobo - kralster's Corsair TWIN2x4096-6400C5 PRO 4GB would be an obvious choice or OCZ Platinum-PC2 6400 4GB (2x2GB). Also, both should have reasonable potential if you plan to OC.
cheers, i'm leaning towards corsair... probably not gonna OC it, just gonna leave it stock and stable
hey everyone, im going to upgrade my ram in the next couple of days and im after some advice. currently it has 2 512MB PC3200 sticks in it. im debating whether or not to just put another 2 in there to get 2 gig of total RAM or swap them all out for single 1gig sticks so i have a total of 4 gig of RAM.
now my FSB is 800Mhz so what are the advantages of upgrading to a higher speed ram as well?
    • how do you know voltage is fine?  quick easy test is connect DMM up and put it on max/min mode, remove fuel pump fuse, crank car for 3-5s, go check min voltage You'd be surprised how many "healthy" batteries are showing under 10v during this test in cold weather.
    • Not properly. You need to be able to dissipate 100 amps or so to doing it meaningfully. You can do it indirectly by watching to see how far the voltage falls during cranking. Unplug the coils or something else to prevent it from starting so you can get a good couple or three chugs. It also helps if you have the multimeter set up reading before you start, and that it has max/min functions. So you can catch the real minimum without having to watch the screen, which often doesn't update fast enough to show the real max/min in dynamic situations. Or use a digital oscilloscope, which can be obtained for <<$100 from Aliexpress (although I'd argue for paying up to ~$200 for a nicer one). A >4 yr old battery will very likely be well down the path to the knackery. Many only last 5-6 years these days. The cold weather lately will definitely make it worse.
    • Hmmm, what do you mean by getting weaker? And where did you get that test done? I've been wondering about my battery because the cold starts crank super slowly. The voltage is fine. Not sure if cranking amps can be checked at home. Battery is 4+ years old.
    • No. The simplest wastegate hookup, with no solenoid or other form of "boost control" (ie, control over your boost control, if you know what I mean) is a single hose, direct from the turbo outlet/hot pipe, straight and only to the wastegate actuator. It is that pressure signal that drives the wastegate to open, providing the boost control (and by "boost control" here, I mean, limiting how high it can go, which is essentially the spring pressure of the actuator). You only end up with tee pieces and alternate flow paths once you start adding things to the boost control system to allow you to determine how much of that boost signal makes it to the actuator. There are so many ways to do that that there is no single way to run the hoses and tees and the like. If you have a stock boost solenoid, then all it does is either allow all the boost signal to go to the actuator, or open up to allow some of it to bleed off. There needs to be a restriction in that bleeder to allow only a small amount to bleed off. And in a stock system, that would then be plumbed back to the turbo inlet (for "emissions control" reasons). That is actually what that nipple on your BOV return pipe could/would be for. If you have an aftermarket boost controller and solenoid, then the above is mostly true, but there is no need for a restrictor in the bleed, because the solenoid is pulse width modulated to create a variable bleed off. The air that escapes from the bleed can either be vented, or also returned to the turbo inlet. For emissions reasons it should be returned to inlet, but the amount of air being vented is so small that it really doesn't matter (either from an emissions perspective, or from an air-fuel ratio affecting perspective).
    • And other times you just need to go buy bigger injectors?
