hey Chops we should do another beer with Andrew sometime.
thanks for all the responses guys, I've checked a few reviews and am definitely leaning towards the logitech (buy it once I suppose)....just have to decide whether to get the Pro9000 or Orbit (Sphere)
Sounds good Pete.
Got a busy couple weeks, as the wife's about to deliver our first in a week or two - no doubt soon after I'll either be looking to celebrate or escape!
anyone else hear of the April the 4th virus in todays news paper just wondering what people have heard
If you're referring to conficker, its due to polymorph on the 4th however most AV companies are on top of it (and MS has released a patch to help prevent damage)..
I for one have been home all day with pharyngitis. If only I could run AVG on my tonsils I'd be much happier.
-D
hahaha i think a CF mouse mat would play havoc of the laser
yeah G19 looks nice i was never really into fancy keyboards
Same, I even prefer the corded mice and keyboards because I was sick and tired of constantly changing batteries in them.
It is a corded keyboard though Norman. I've used cordless keyboard and mouse before - the mouse chews up batteries mainly. The G15 V1 and V2 and G19 are corded same with their pro mouse the G9.
I got the G15 V1 - the G19 doesnt seem to be that much of an upgrade worthy of upgrading yet... my MX510 mouse on the otherhand - I so want the G9.
yeah i got the g15 v1 too.... only problem is the paint wearing off the keys ;\ I dont have an 'S' key anymore, its just a dot...
-D
Keyboard maybe but not on a mouse!
Agreed. I have a 5 year old wireless logitech MX mouse and it never stopped me from getting to the top 3 SOF2 players on the Telstra and optus servers back in the day. Gamers who blame their mice are really laughable :D
-D
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
