ive used 7057 for over 8hrs a day since i bought Brendans old hardware which i think might be 3 weeks ago and have come across no issues im really quiet happy with it
its punkbuster im spewing at for not supporting a new OS
you know i do :down: get a few BOOM headshots like this
love the slow mo BOOOoooooOOOOOM HeeeeEEEaaaaAAAADDDDD SHOT!
this footage was a clutch in a GA war
hey i just found my sof2 discs
will let u know when its installed/upgraded
-D
I have a spare Battlefield Heroes Beta key if anyone wants it.
Is anyone else playing it? I can play for 4 minutes, then I get kicked due to 'connection issues'. But my net and everything still work fine. One guy on the forums guesses that all of the beta severs are in the USA (which would make sense), and we are getting massive packet loss here - so after 'x' amount f packets have been sent and cropped by my PC, the game senses I have connections issues, even though I really don't.
Anyone else playing and have this issue?
Damn cool game though - and the customisation of clothing/weapons/skills is a very cool concept..
you are no longer my friend Andrew the game sux bollocks
ill repeat
BF heroes is a game made by 6yr old's for 6 yr old's
hey Craig i beat that other guy tonight for a 6win streak
k i got sof2 installed, what addons do i need ? Ive already installed the gold patch
wot server u on?
-D
im off to bed tomorrow i can either email you the OSP mod or something and we play cyber gamers server CG for short
OSP is version 1.0 if you want to search around tonight
i would suggest getting xfire and ventrilo is always fun too
    • R34DE as in R34 with an RB25DE? So did you get this? Or you planning to?  I'm not really sure what you're saying.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
