its in all the use of joining words some say schematics
i said used to be in its hey day which makes the statement correct
you use the words
dos 6.2 is a totally awesome....
where if you used was then that statement would also be correct
Has anyone tried Facebook Lite? I actually prefer it to the normal Facebook because it runs more like a normal website, as it cuts out a lot of the unnecessary AJAX crap that slows down the site. It's accessible at http://lite.facebook.com
just about to get new broadband at home..
is 20gb p/m enough if i want to smash online play on my ps3?
and should i go adsl2+ or adsl?
any recommendations?
20 gigs should be more than enough. Try Adam Internet ADSL2+, works well here, and you get 20 gig in peak hours (8am-midnight) and an extra 20 gig off-peak (midnight-8am). Cost is about $55/month AFAIK.
also why internode over adam?
if you want quantity = adam
if you want quality = internode
101% internode, been a customer for 8 yrs and have had less than a handfull of issues over that time. excellent service and support. what more can one want?
-D
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
    • You can probably scrub the rust with a toothbrush or something. After you get the rust off flush well with water to neutralize and you will probably want to also use a fuel tank sealer to keep it from rusting again.
    • The sodium citrate solution is designed to buffer the citric acid to keep it from attacking metal quite so much, the guy that came up with that recipe did a ton of testing on how much metal loss occurs over time and it's nothing crazy unless you forget about it for months:
