  • 4 weeks later...
hey guys,
can anyone reccomend a good legit FREE pdf reader/editor?
i have tried haxt version of adobe 8 pro in the past, but win 7 64 bit does not wanna know about it
Foxit
Bullzip
CutePDF
Most 4870 cards are a bit noisy, trying to keep my system as quiet as possible. 2 4870's also give more performance than one 5870 so worth the relatively small investment
5850 would be good enough by itself, but don't really want to spend that much. 4800 & 5800 series cards are also not compatible:
http://game.amd.com/us-en/content/images/c...combo_chart.jpg
didnt realise they weren't compatible
trying to find a review of the 5870 against a CF 4870 might have to look later
what type of motherboard have you got i did read that if its a 16x/4x you might be better off with 1x 5870 but there like $600
Running a Core i7 920 clocked at 3.2GHz on a Gigabyte EX58-UD5 motherboard. Can run 2 cards at full 16x speed.
If I end up making the jump to a 5870 it won't be until they have halved in price. Not going to happen for a while though, especially since Nvidia is yet to release their competitor. I have a feeling they've been caught with their pants down & weren't expecting ATi to improve as much as it has in the last couple years. Either that or they're looking to make something that will totally dominate, though they may run out of development funds if they don't look out.....
imo ATi will bring a 5990 out soon after the fermi to try and keep a wrangle hold on the market may work it may not i dont know much about Nvidia as they dont hold my interest
that board is pretty nice 3 way CrossfireX or SLI 2 @ 16x and 1 @ 8x
so its the **70 series or nothing you wouldnt consider 5850's i run 2x 4850's in a OC Q6600 and score 18k in 3dmark 06
>>3d mark 06 18916<<
back when i tried a 7800GTX it didnt perform up to the hype and i stuck with ATi
>>3dmark 06 7800gtx 4069<<
>>3dmark 06 x1900xtx 4990<<
Actually for 3 way SLI it works out to be 16x8x8. It splits the second lot of 16 lanes over the lower 2 cards in 3 way SLI. Completely useless though unless you happen to own a super expensive hi-res +30 inch monitor. 2 slots is pleanty :cheers:
2x 5850's would be awsome, but still rather pricey at the moment & a bit overkill IMO. If I can get a second one of these cards it will be by far the best bang for my buck at the moment, just going to have to keep an eye out.
2x 4850's should see some pretty good performance, probably starting to push the limit of your CPU.
yeah 1ghz OC is enough
i didnt read that mobo as that but you would know i only read the stats page from gigabyte
yeah i think 2x 5850 is like one 5870 prolly a little more for the 2x 5850 dont look @ prices or ill want a new system and mine is good enough
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
