2x 5850's will KILL a 5870. The difference between the two types isn't that great. A 5850 is basically a cut down version of a 5870, with about 70-80% of the processing power. Put 2 of them together & you do the math....
Same goes for 2x 4850's vs a 4870 or a 4890. In fact I think I read reacently on Toms Hardware that they were about the same performance wise as 5850.
There's nothing wrong with the system you have, should be able to make it last a bit longer yet.
yeah i also bought the gigabyte OC version of the 4850 because i think its core clock was 75mhz faster than standard
so you have like:
4870 @ 750mhz
4850 OC @ 700mhz
4850 @ 625mhz
so spend a little more and it come with a better cooler from zalman too
>>This Article<< helped me choose the 4850 OC as id did very simular performance to the 4870 in the gigaFLOPS
have you tried MSY or they dont have the ICEQ4
This is the major issue now. No one has any 4800 series cards anymore, just when I was ready to buy my second card they dissapeared off of the shelf in prepariation for the 5800 series cards.
I actually got my HIS card from Allneeds as MSY didn't sell this card (also an OC job 770MHz instead of 750, not quite as big a gain that way, but the price difference wasn't that great), and they also have much better service with still competitive prices.
Also went for this because the equivalent Zalman fanned Gigabyte model was actually quite noisy unlike the 4850 version.
It was inevitable, after 3 1/2 years of having pretty much the same computer, I decided that this weekend was going to be the time to finally upgrade my computer.
Previous specs were:
-AMD Athlon64 3500+
-Gigabyte K8 Triton Motherboard
-4x512MB DDR2(?) RAM
-Gigabyte Nvidea 9800GT
-2x160GB, 1x320GB & 1x640GB HDDs
-DVD Burner
-Netgear Wireless Network Card
-Fusion HDTV Pro Card
-Themaltake Soprano Case
-Windows 7 64-bit Ultimate (RC)
Now as it stands, its:
-AMD AM3 Phenom II x4 965 3.4Ghz
-Gigabyte GA-MA785GT
-2x2GB DDR3 RAM
-1x160GB, 1x320GB & 1x640GB 1x1.5TB HDDs
-DVD Burner
-Thermaltake V9 Case
-Windows 7 64-bit Ultimate (RC) (Still to reformat and go to Win7 64-bit Home Premium)
Here's how the upgrade went...
Went to MSY in Plympton and bought all the gear necessary... cost me about $800.
New case sitting ready to go
New motherboard ready to go in
After having some issues removing the standard plug stencil panel, finally got the motherboard in
CPU and heatsink ready to go in
CPU set into the socket
After stuffing around with the heatsink, finally got it on properly
Memory ready to go in, haven't had one with a heatsink before :)
And sitting nicely on the board
This is where I finshed off on Saturday night, all the connectors attached
Sunday arvo I disconnected my current case and was ready to raid the remaining parts from it
Then put all the hard drives into their respective bays
Video card was a bit dusty, so a bit of cleaning got rid of most of the dust
Had to get rid of one of the HDDs as the motherboard only has room for one IDE drive :)
Then transferred over the graphics card, TV card and wireless network card
Next was transferring the PSU, but the secondary cable (no idea what it's called) wasn't long enough, so I got my brother's old PSU and put that in instead.
Then proceeded to installing the DVD drive
Still have somewhat of a mess in regards to HDD cables, but it's a lot better than it was before
Then closed up the case and it's ready to go!
Funnily enough, Windows proceeded to boot up with my old Win7 RC install, and after some driver installation and a restart, it was all working fine :down: I would have thought a complete reformat would have been necessary, but no, Windows 7 seems to really be that good!
CPU is running at a constant 38-40C, which I believe is a good temperature to sit at.
Now all I got left is to set up my old case for the parents, which only requires the removed hard drive, a new video card and some basic claening, as well as installing my old copy of Vista.
Below are the WEI scores:
Previous specs:
Internim specs:
So far the system's been very fast with all the Windows 7 functions, but a complete reformat on a SATA drive will really show off the system's shine.
nice one Norman i have the same case
its very good to build with, my only gripe was where you put the hdd in getting the SATA cables back to the hard drive there could of been more room but that could also be design faults with the P5E deluxe has 90deg connectors :):down::)
good to know it wasn't just me
the case i really wanted was the HAF932 or 922 but only wanted to spend a little over $100, in saying that i am very happy with the case even if it is TT's cheap range
  Aberax said:
Have a look at StaticIce or...if all else fails, Ebay
  Madaz said:
Nothing on fleebay at the moment, all those links i posted were from a staticice search :P
Thanks for this guys. Didn't know about Static Ice, has given me renewed hope. May even call Allneeds just to see if they can still get them, if not these are priced reasonably & will give me the killer performance I am after. The main game I've got at the moment that struggles is Stalker Clearsky. Would be a lot more fun with 2 cards on the go
  Normsta said:
I wanted the Antech 300 case, but all the MSYs were sold out of them. Hopefully this one'll last a while. How long have you had yours?
There's a snag with the Antec 300 case, it only comes with one fan, so if you want it to cool sufficiently you need to spend extra on another fan for the front at least.
hey guys, have just moved to sa (christies) from qld. just wondering, is MSY "it" for pc bits in sa?
where i lived i had a choice of umart and msy, but msy were always ultra shithouse in terms of customer service and actually getting exactly the parts you were after...
going to be chasing some i7 goodness in a few months i reckon! time to start researching again! :P
msy are the cheapest, their customer service and parts availability still sucks but they do have several branches for you to choose from. for what its worth i still order most of my stuff from pccasegear.com.au which is based in melbourne.
-D
going to be chasing some i7 goodness in a few months i reckon! time to start researching again! :D
Go i9, ETA is First Quarter of this year.
...You also have IT Warehouse in SA too, your closest ones are at Christies/Noarlunga on Dyson Road and one at Marion on Marion Road, excellent service from these guys :P
Isn't IT Warehouse at Noarlunga for sale?
Don't mean to bad-mouth the place, but they used to be alot bigger than what they are now a few years back. I was good mates with the manager there for years (Brendan I think?) but I think he's moved on. It's hilarious that he was told to bring in those water tanks to sell :| I saw no point in that, but apparently that was word from higher-up.
These days the place is heaps smaller and seems alot emptier? I swear it was bigger back when it was still open on Beach road hahaha and that was god knows how many years ago now.
I just finished Stalker Pripyat last night .... awesome game. COS and CS were good too, but Pripyat melds the best of both together. You are lucky you are playing CS now - I bought it the day it came out and couldn't even play it, it was so full of bugs. Took no less than 5 patches (which erased my saved games each time) to finish the game (so I played around 3200 hours all up believe it or not). I have NEVER had so many blue screens of death in my life. I followed the Russian forum chatter closely and everyone was having the same issues - they released the game under significant time pressure and barely beta tested it at all.
I played all 3 with my single 4850 1Gb and they managed, but only just. Pripyat is the most demanding - at 1920x1200 with everything set high it did struggle in the big battle scenes.
Yes and No, we are wanting to move into a smaller store, however our lease isn't up yet, so we are trying to find someone to sublease to - hence the for sale sign out the front.
Ah Yes, Brendan, He now works at NextByte, selling Apple's to Schools, etc.
It was great years ago, nice and open, but we started having the amount of staff we could have on cut back, head office started getting lazy - not sending us what we wanted/less of what we wanted, and stock getting stolen was too hard to handle with a store that size with 2-3 staff. So that's why it was downsized, to make it more manageable, and a storage area out back for furniture and those infernal tanks.
It was bigger back in the day when we got what we ordered from head office, now it sucks, we order 10 of an item, we get sent 0-5, and they don't keep there stock levels up, so we have to wait longer for stock to arrive. In 2009 we had an awesome range of Superflower cases, the SF800-SF1000 series, we sold out of the stock back in Nov/Dec 2009....it is now March 2010 and still no stock of them :)
-D
cheers mate :P
...You also have IT Warehouse in SA too, your closest ones are at Christies/Noarlunga on Dyson Road and one at Marion on Marion Road, excellent service from these guys :down:
o rly?! am scoping specs now... thanks for the details about IT Warehouse too :D
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
