Hey guys, Ive got a really weird problem. I have just changed ISP's and my email doesnt work anymore.... Not 1 setting on the PC was changed (because I use ethernet), and the email I use is Hotmail with Windows Live Mail as the program... WTF?!?
Might be coincidence you say? The bigpond email wont work on my laptop either, which is connected by wi-fi using Windows Mail.
Kinda baffled here :(
1. What Firmware is it running? Should be printed on the top...pray to god it isnt the faulty batch of SD15 drives - they shouldnt have been released in Australia anyway, but grey importers, etc bring them in.
2. Have you tried a different SATA cable and SATA port?
3. Have you tried resetting the BIOS.
4. +1 Does the drive spin up at all, or make any weird noises?
Nothing too much you can really do with hard drives. Sometimes you can change the controller card, but you need one from a working exact same model and firmware drive, even then it isn't guaranteed to work. You can try a data retrieval place, if the data means that much too you, but be prepared to pay ~$1000 or more - They take the drive apart in a special chamber, take the spindle out, and place it into a spindle reader.
He cant get into Windows as the 1tb drive is his C: Drive - The drive Windows is on, and the Bios doesn't see it.
1. Firmware = SN04
2. Yep, and other drives work off of the same cable and port.
3. Nope, but the issue is that sometimes the PC will hang during the POST, and the BIOS always fails to recognise 2 of the other drives when this drive is plugged in = not good and also strange.
4. The drive does spin up, and with no weird noises, so that's something.
I'm fairly sure if I had access to another drive with the same f/w rev (or maybe even different f/w) the board could be swapped and the drive would work.
thats in a coffee time patch ;)
heh nice. they should also put in an 'infidelity timer' so if u take too long playing with the whores, elin nordegren pops up with a golf club and its your job to evade her, make your way to the black SUV and drive out of the gated community to south central LA, where another whore is waiting...
too bad tiger didnt take notice of the timer
-D
Woot.
Uranus is back and waiting for me to fill it again. :D:blink:
Now if only Saturn would work again...
***Probably only Dohmar will know what I'm referring to***
It means that daves favourite hoe is back in adelaide
but he laments the loss of another good (retired) hoe..
nah thats not right... >:)
-D
going to do a grandparent thing here..
"I remember back in the day that this thread was only a few pages long"
i was talking about getting a new pc..
I FINALLY DID YAY :(
hehe grats i know what thats like
took me 12 months ;P
-D
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
